Results 1 to 3 of 3
Thread: Creating a template
    Chris Hatfield is offline Former Member (by the member's request)
    Aug 2010
    380
    Creating a template
    Now that I have my bandsaw, I am closer than ever to getting this kitchen table project started.
    My first step is to make the chairs. To do so I need to make the chair legs, which means I need a template. This is where I have a little trouble. I don't know how to make the sweeping curves an lines look like they belong. I attempted to make one a few weeks ago but it was very lumpy.
    Any tools I can use to make sure I get these lines right? And should the width of the leg be mostly constant throughout?
    30,002
    There are several ways to draw a sweeping curve. Here's an article that covers several of them...
    http://www.finewoodworking.com/FWNPDF/011175073.pdf
    (I think it's viewable without having a Fine Woodworking web subscription.)
    I've used a thin strip of 3/4" hardwood on edge (like the batten the article describes starting on page 74) bent to the shape I wanted and held in place with small finishing nails or push pins.
    Woodstock, Ontario, Canada
    719
    For a sweeping curve I would make up a 3' long x 1/8" thick x what stock U have and use a string to tension it to the curve I want.sort of like this Lee Valley one
    hobby woodworking since 1972
  1. Sheild Template
    By Leo Voisine in forum General Woodworking Q&A
    Last Post: 04-05-2015, 04:50 PM
  2. Creating and cutting with a template
    By Shawn Anderson in forum General Woodworking Q&A
    Last Post: 06-21-2014, 12:07 PM
  3. Template Routing Jig - v2
    Last Post: 12-12-2011, 12:47 PM
  4. SKETCHUP Template
    Last Post: 03-13-2009, 05:44 PM
  5. Creating A Three-Cornered Miter
    By Keith Starosta in forum General Woodworking Q&A
    Last Post: 04-12-2008, 01:55 AM
