Results 1 to 10 of 10
Thread: Aromatic Red Cedar
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Aromatic Red Cedar
    Fitted with a Modified Perfect Fit 1/4 Twist Ballpoint.
    Twisting the nib clockwise extends and retracts the refill.
    Unscrewing the nib anti-clockwise allows access to the refill.
    Sanded to 400x, buffed with Super Fine Steel Wool and applied 6 coats of MINWAX Clear Gloss Polyurethane.
    No buffing or polishing on the MINWAX finish required.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    30,017
    Beautiful work as usual, Les. Did the cedar make your shop smell good, or was it a big enough piece to do that? (If I turn a cedar bowl or hollow form, my shop smells great for a week or two afterward.)
    11,832
    As always, very beautiful.
    Would you mind telling us how you make a one piece pen out of a two piece kit?
    S E Washington State
    3,777
    I never would have thought cedar could be that pretty.
    "We the People ......"
    Jan 2011
    1 hour north of Toronto
    38
    Very nice Les, i'm really liking those one piece pens and the way they present the wood.
    That's really nice... I wish I knew how to turn these one piece designs, as they seem to be among the best designs for showing off a really nice piece of wood.
    Goodland, Kansas
    4,834
    That is one nice pen. I do like turning cedar because of the color. That pen really shows it off. I really need to see how to turn one of those and give it a go.
    Bernie W.
    Apr 2009
    1,083
    Thanks Vaughn,
    Yep, the shop smelled great, even with turning this small blank.
    Great stuff to turn and finish.
    Les
    Apr 2009
    1,083
    Guys,
    To make a modified kit: (Slimline Kits)
    1. Ensure the blank is square
    2. Cut the blank to length including the center band
    3. Drill the blank dead center using the appropriate drill bit
    4. Glue in the cap end brass tube
    5. Drop in the nib end tube and mill both ends square to the tubes
    6. Remove the nib end tube
    7. Knock the edges off the blank with the band saw
    8. Turn the blank between centers to fit the finial and nib
    9. Prepare and apply finish to the barrel
    10. Install the nib, transmission and refill into the other brass tube
    11. Install the Finial and Clip into the cap end of the barrel
    12. Push the nib assembly into the barrel and check operation
    Twisting the nib should easily extend and retract the refill
    Les
    11,832
    Printed and saved.
    Methinks will have to do several to get the knack down pat.
    Twisting the nib. OK, I was puzzling over the process by thinking it was the clip tha wuz turned.
    Thanks. Come warm up (it's getting there) I'll try.
  1. So That's Where All the Cedar Goes.
    By glenn bradley in forum Off Topic Discussion
    Last Post: 04-29-2013, 04:47 PM
  2. Cedar Pot
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 09-23-2010, 03:24 PM
  3. Red Cedar
    By Cynthia White in forum Carpentry and Construction
    Last Post: 07-23-2010, 09:26 PM
  4. A little cedar box
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 03-18-2009, 01:19 AM
  5. and some more in cedar
    By Bill Pealer in forum Lathe Project Showcase
    Last Post: 01-01-2008, 01:20 AM
