Results 1 to 4 of 4
Thread: Variable Speed-Induction Motor
    Good afternoon! First, I am not much of an electronics "guru." I have done some "more than mild, but not yet wild" electricial wiring, but am a musician by training.
    Anywho, I have my grandfather's circa 1940 Beaver wood lathe. It's heavy and well-built with an induction motor. It has 3 pulleys and that is it for speed control.
    My questions are these......is it possible to buy a speed control unit? What are they called and what can I expect to spend for a 1HP unit? As it is now, I have but 3 speeds....all of them far too fast for roughing out bowls.
    Russell
    Nova Scotia's beautiful south shore
    443
    Hi Russell
    Welcome to the forum. There's been some discussion on this recently on the forum. Check out this thread
    http://familywoodworking.org/forums/...ead.php?t=2160
    It starts out with DC motor information, but others sraightened me out and we got some good discussion on AC induction motors.
    The short answer is, no, it's not practical with a single phase motor. In addition to that, you could easily surpass the value of your lathe with the items you need to convert it.
    Cheers
    All the best,
    Ian G
    **Now holding auditions for a catchy new signature**
    The Heart of Dixie
    4,268
    Well Ian just covered it!
    About the only reasonable option is adding a jackshaft with a set of pulleys between the motor and the lathe. Unless you get lucky and find a surplus VFD and 3 phase motor cheap or a DC motor and controller cheap.
    You might check The Surplus Center, sometimes they have the DC motors and controllers. I picked up both for around $125 from them for a lathe project.
    Jeff
    Custom built boats and Kits
    15,811
    HI Russell
    The other thing you can do is to find a 5 step pulley for the motor and the lathe, and figure out if that would give you speeds that are slow enough, I think that the Sears tube lathe or the Ridgid one would be good places to look, depends on the shaft size of the lathe and motor you have now.
    Otherwise like was said by Ian, a VFD and a 3-phase motor are the way to go.
  1. Convert 1 Phase 1 HP Motor to Variable Speed ?
    Last Post: 04-30-2014, 03:06 PM
  2. Replies: 10
    Last Post: 11-07-2013, 08:44 PM
  3. Free 1hp induction 3450 rpm motor
    By Jim C Bradley in forum Giveaways, Contests, and Swaps
    Last Post: 08-09-2011, 05:36 PM
  4. Variable speed motor drive for your tools ...
    By Ian Gillis in forum General Woodworking Q&A
    Last Post: 02-19-2007, 04:43 AM
  5. Questions about Delco Repulsion Induction Motor
    By scott spencer in forum Old Iron
    Last Post: 01-16-2007, 08:55 AM
