Results 1 to 10 of 19
Thread: Shop Fox drill press question
    Aug 2010
    Knoxville
    10
    I'm looking to replace my worn out drill press. The Woodworkers Journal has a nice review of drill presses in the Feb issue, and the Shop Fox W1668 caught my attention.
    I looked on line, and looked thru the manual, and it appears that the chuck is not a MT2 type. Since I have a keyless chuck I really like, I would like to transfer it to my new drill press, but it has a MT2.
    Does anyone here own this drill press, or know if it has a MT2 chuck?
    Thanks
    Bellingham
    2,449
    Looks like it has a JT-33.
Name:	Drill Press W1668.jpg
    30,014
    Jack, do you know if your keyless chuck can be removed from the MT2 spindle it's on? It will probably take a fair amount of convincing to get it loose, but if it can come off, I'd be willing to bet that the taper in the chuck body itself is a Jacobs 33 taper, like the one on the spindle of the Shop Fox drill press.
    The other option would be to just get another keyless chuck...
    http://littlemachineshop.com/product...php?category=7
    Aug 2010
    Knoxville
    10
    Since the keyless chuck is fairly new, I can probably get it off the arbor. It looks like the one thats listed on the site Vaughn listed.
    Maybe there is hope after all.
    I rea;;y hate to buy another one since this one is less than a month old.
    Orem, Utah
    935
    I'm with Vaughn. I have a keyless chuck on a JT-to-MT2 arbor that I use in the tailstock of my lathe, and a second one that's "permanently" mounted in my drill press.
    No more chuck keys!
    Aug 2010
    Knoxville
    10
    I just looked at my keyless chuck and it says 5/8" JT3. Is JT3 the same as JT33???
    30,014
    Quote Originally Posted by Jack Feldmann View Post
    Nope, they're different. See the chart on page 2 of this PDF file:
    http://www.jacobschuck.com/pdf/Techn...nformation.pdf
    You might be able to find an adaptor for it, but any adaptor adds the potential for additional runout.
    5,321
    My Shop Fox radial drill press has the JT-33.
    If your chuck is a Jt-3, then it's not compatible with the S-F press.
    Enco has several different keyless chucks from their own brand ($40.00+) to Albrecht ($200.00+).
    I have two of the Enco brand, - one on my Powermatic press, and the other on my Shop Fox - and they've been just fine.
    Jun 2010
    3,220
    Hi Jack, Welcome to the Family. Delighted to meet you!
    AKA The Rookie
    Orem, Utah
    935
    Found the owner's manual at
    It says:
    The Spindle Taper of JT-33 must refer to the "business end" of the arbor (the end that the chuck mounts to) and not the upper end that mounts the arbor to the machine.
    In other words, the JT-33 chuck (female) taper fits onto the exposed JT-33 spindle (male) taper. Duh. What they DON'T say is which Morse Taper is on the upper end of the spindle arbor. My guess would be MT2, but I suppose an MT3 taper is also possible. For more on this general topic, see this informative page:
    Now ... check out this search results page that shows "all things JT3" from the Grizzly catalog:Notice that they offer replacement arbors (that will fit your JT3 chuck) with 3 different Morse Tapers: MT2, MT3 and MT4. All you need to know now is the actual Morse Taper on the upper end of the arbor.
    Oops! Hold the phone! I went a little further in the W1668 owner's manual, and found the following parts info (on pages 30 and 31):
    I'm still willing to bet on the upper arbor taper being MT2, but I don't like the "extra" bit that I'm seeing in the diagram:
    It could just be an extra piece that's screwed into the arbor, but it could also be a custom arbor, designed specially for the cool oscillating action. I say this because of the following info on page 13:
    That raises a whole new issue. Suppose you go the easier route and just buy a new (keyless, JT33) chuck to replace the stock one. Would "generic" chucks like those sold by Grizzly be compatible with the capscrew mounting/tightening arrangement described in the manual?
    Hmmm ... time to punt. Maybe give Shop Fox a call?
  1. Drill Press Question
    By Allen Bryant in forum General Woodworking Q&A
    Last Post: 04-13-2014, 01:26 AM
  2. Drill Press question
    Last Post: 12-18-2010, 12:10 AM
  3. drill press question
    Last Post: 07-18-2008, 01:45 PM
  4. a question for a box for a 75lb drill press
    Last Post: 07-14-2008, 05:41 PM
  5. Drill Press Question
    By Dave Richards in forum Old Iron
    Last Post: 06-26-2007, 01:53 AM
