Results 1 to 9 of 9
Thread: Issue with a Makita 2012NB Planer
    Manistique, Michigan
    297
    I have had this planer for 10 years. It has always been decent until a few days ago. Normal width boards run well through the planer. There has aways been a hint of snipe, but normally not a big issue.
    I ran 4 glue ups through the planer at almost width capacity (12"). I have a Wixey planer thickness gage on the unit. Taking 0.005" at a time, the last 4 inches on one side had chatter. It was like the head lock came loose or something. If I put pressure up on the board, it got worse. I adjusted the outfeed and infeed so they did not put as much pressure up on the board and made matters worse. It always happens on one side an normally is about 3" across the board. The deep ones were about half way across.
    Any ideas of what might be the problem? Bad out feed roller or infeed roller? Head lock not working correctly? Bad bearings? Bad chain?
    Rich (the Yooper)
    "To the world, you may be one person, but to one person, you may be the world."
    "Common sense is not so common."
    NH
    4,005
    When was the last time the knifes where sharpened?
    Stupid hurts.
    11,832
    Try waxing the bed. Made a big difference when I had similar problems with my Grizzly. Nebber woulda thought about it but got advice here.
    And it worked.
    297
    When this happened, I installed a new set of blades. Unfortunately, the problem was still there.
    Rich (the Yooper)
    297
    And it worked.
    I read about doing this, but didnt know if it would help. I'll pick up some wax tomorrow and try it. This makes sense because narrow boards come out very well. The panels were almost maximum width this planer will handle.
    Rich (the Yooper)
    17,472
    rich narrow boards have less friction surface than a wide board..so maybe its the wax fix to the rescue..
    297
    Larry - that is what I was thinking also. It is certainly worth a try.....but now I have to make another glue up to try.....so that means i need to make another cabinet that needs a raised panel door.
    You are just trying to keep me away from that spinny thing.
    Rich (the Yooper)
    17,472
    i do know for sure that dull blades will cause trouble, and the wax wont help dull blades but you have said yu changed them out so its the slick surface problem next.. just take a wide board of anything and run it threw there..doesnt need to be a glue up..
    297
    Good point. I have some 10" wide lumber that should work.
    Rich (the Yooper)
  1. Makita 2012 NB Planer Issue Resolved
    By Rich Aldrich in forum General Woodworking Q&A
    Last Post: 02-15-2011, 02:34 AM
  2. Planer outfeed issue
    By Darren Wright in forum New Tools
    Last Post: 11-18-2010, 12:20 AM
  3. Makita 2012NB Planer
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 02-13-2009, 12:38 AM
  4. Makita 2012NB $248
    By Bob Luciano in forum Hot Deals
    Last Post: 06-22-2007, 09:36 PM
