Results 1 to 10 of 15
Thread: Ladder Stairs
    Ladder Stairs
    I am building a ladder stair to get to a loft. I don't have space to install a normal stairway. I purchased Basic Stairbuilding by Scott Schuttner and he addresses ladder stairs in the book but he doesn't really say how to make the upper cut of the carriage. I have tried several methods and none have worked. I am having a brain block, so I need some assistance. I have made the bottom cut and it's set to a 57 degree angle. I have the other dimensions if needed.
    Here is the criteria I need to follow:
    1) I want the top of the carriage to be flush with the loft floor, which is approximately 9' 5-1/2" from the floor.
    2) The bottom of the carriage must stay at the original location, it cannot move forwards or backwards due to doors in the area.
    I have attached a pic of this.
    Jun 2010
    3,220
    Welcome Dennis! It's your first post since summer of '09? Wow. I'm sure you get some useful responses to your ladder question before long.
    Welcome.
    AKA The Rookie
    well I believe that this is the angle you are looking 4
    I figured it was 33 degrees, but when I lay this board in position how do I mark the board to make the cuts? That's where I am having the problem. I can't get the length of the board correct so that it is level with the loft floor.
    If you drop a plumb line from the loft to the floor what is the distance from the bottom of the board to the plumb bob
    The distance from the loft floor to the bottom floor is 9' 5-1/2". By bottom of the board I assume you mean where the 2x6 meets the loft floor?
    Quote Originally Posted by Dennis Dusek View Post
    that is correct. u know one side of a right triangle if you can measure the distance from there you will know the second side andf can calculate the third side.
    maybe this will clear things up
    Yes I can calculate that. I thought you could just mark the board at the top when it was in place to indicate where to make the cut(s). Maybe you can't do that.
    So Dennis, just what is it you want to know ? I am a little confused ?
  1. Under-The-Stairs storage cart.
    By Art Mulder in forum Carpentry and Construction
    Last Post: 11-27-2014, 05:03 AM
  2. stairs
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 11-17-2008, 10:23 PM
  3. Stairs. Yikes!
    By Bill Lantry in forum Carpentry and Construction
    Last Post: 07-20-2008, 07:11 PM
  4. width of stairs?
    By Chris Mire in forum Carpentry and Construction
    Last Post: 08-17-2007, 11:49 AM
  5. Stairs and Rails, (Pics)
    By Richard Wolf in forum Carpentry and Construction
    Last Post: 11-24-2006, 12:59 AM
