Results 1 to 6 of 6
Thread: A (very) purpose-built bench/cabinet/shelving unit
    Toronto, Ontario, CANADA
    2,332
    (part 1 of 2)
    Last week, in the thread http://familywoodworking.org/forums/...ead.php?t=1769, I said “I still need to build a spot to hold the router table top when it is not in use. In the next week or so, I will build a cabinet in the spot shown below:
Name:	The router top will be stored in a cabinet I will build here -small.JPG
    This week, I built that shelf/cabinet/bench unit.
    Here are a couple of pictures of the finished, definitely purpose built, and somewhat convoluted unit:
Name:	Complex shelving unit 11 -finished -front view -small.JPG
ID:	4933 Click image for larger version.
Name:	Complex shelving unit 12 -finished -corner view -small.JPG
    Not only is this to used to store the router table top, but it is to be used to store a couple of bench machines that did not have a home, to store three Festool systainers, a column of Veritas drawers, and some other odds and sods that previously did not seem to fit is well anywhere.
    Cheers, Frank
    Steve Clardy Guest
    Hey! I like it Frank
    Neat idea on the metal drawer units
    2,332
    (part 2 of 2)
    Here is a series of pictures depicting the construction:
    01) I started by building three units. They were made mostly from 18 mm thick Baltic Birch.
Name:	Complex shelving unit 01 -start by building 3 sections -small.JPG
    02) My shop assistant of the day, my granddaughter Isla, applied Varathane to the units:
Name:	Complex shelving unit 02 -Isla applying varethane -small.JPG
    Isla is also my resident shop “artist” and she can’t resist drawing something on everything that she works on.
    03) Next, I added some parts, making the section seem even more convoluted:
Name:	Complex shelving unit 03 -add some parts to make right side even more complex -small.JPG
ID:	4937 Click image for larger version.
Name:	Complex shelving unit 04 -another view of the right side -small.JPG
    It is beginning to look a bit like an abstract sculpture.
    04) Next, a simple plinth was installed:
Name:	Complex shelving unit 05 -simple plinth -small.JPG
    05) Rollers were installed on both side units and the units were tested for fit on the plinth:
Name:	Complex shelving unit 06 -position left and right sides on the plinth -small.JPG
    06) Two drawers to hold Festool systainers were installed, the middle shelves were fitted, and the router table top was tested on the rollers:
Name:	Complex shelving unit 07 -insert drawers and try router table on rollers -small.JPG
    07) The sections were screwed to the plinth and a drawer was installed in the middle section:
Name:	Complex shelving unit 08 -screw sections to plinth and add drawer to middle section -small.JPG
    08) The bottom part of the bench top was screwed on:
Name:	Complex shelving unit 09 -install bottom portion of top -small.JPG
    09) The top part of the bench top (consisting of ¼ inch hard board over ¾ inch MDF) was glued-up:
Name:	Complex shelving unit 10 -glue up rest of top -small.JPG
    This was subsequently screwed (but not glued) to the plywood top, three coats of Varathane were applied, followed by three coats of paste wax.
    Cheers, Frank
    810
    Very nice Frank. Compact, usefull, and attractive to boot. You're also very lucky to be able to have your grandchild working with you.
    cheers eh?
    Tampa
    281
    NIce work Frank.
    One question, why did you make the base for the router table like that, the piece that spans the two side cabinets and sorta sets on a cleat on the left and a slot on the right side?
    2,332
    Quote Originally Posted by Julio Navarro View Post
    NIce work Frank.
    Julio, I hope that you will see why I built it this way if you look at the picture with item 16) in post #23 in the thread: http://familywoodworking.org/forums/...ead.php?t=1769
    Cheers, Frank
  1. Shelving Unit Questions
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 03-08-2014, 06:37 PM
  2. Built In Cabinet Design
    Last Post: 06-12-2009, 04:19 PM
  3. Built-in bench with baskets
    By Westley Rosenbaum in forum Flatwork Project Showcase
    Last Post: 02-06-2009, 04:26 PM
  4. Plywood shelving unit
    By Dave Trask in forum Finishing School
    Last Post: 07-08-2008, 09:07 AM
  5. ?s on my built in work bench assembly.
    By Jim O'Dell in forum Carpentry and Construction
    Last Post: 04-23-2007, 11:39 PM
