Results 1 to 10 of 11
Thread: Can I actually "ZAP" my Nicads back to life?
    May 2009
    Lafayette, Indiana
    2,380
    Ok, many of you here are going to think I have lost my mind and maybe I have but I have been reading several articles tonight about how to bring my old dead rechargeable Ni cad (cordless drill) battery packs back to life. I have read everything from smacking them hard with a block of wood to "zapping" them with higher voltages to placing them in the freezer. The theory is that the cells have produced "crystals" within themselves and therefore short themselves out. By zapping them you break down these crystals and the cells will then again take a charge and continue to work again. The idea is to apply twice the voltage for just a few seconds then check the voltage with a meter until it responds with about 2 volts over the rating of the pack. Has anyone ever tried this?
    I read all this here on the INTERNET so it MUST be true. Right?
    Yes I know the battery will not be covered under warranty anymore and yes I understand that they can overheat and explode. So I am not suggesting to anyone to try it. I'm simply thinking of trying this for myself.
    Here is a link to one of the places I was reading. http://ysuusy.com/easybatteryfix.html
    Central NY State
    3,374
    I tried those things - the freezer, the car battery. Zip, nada, zero.
    I've done it to my 2 ridgid 18 volt nicad batteries. I used my mig welder to do it. I used a setting that had about 24 volts on it and then tapped it across the terminals. Before I did it the batteries would not take a charge. Now they will take a charge and would only charge to about 13 volts. After they sat for a few more months I did it again with another 18 volt battery and now they charge to their full 18 volts. Why that is I don't know but All I know is that I have 2 more batteries to use again.
    more information then you probubly wanted...http://homepage.ntlworld.com/wilf.james/nicads.htm
    30,017
    I've not tried it, but if the packs are dead already, it doesn't seem like you have anything to lose by trying it. (Taking appropriate safety precautions, of course.)
    Mar 2010
    Decatur, Alabama
    518
    I used to race RC cars back in the day with nicad batteries, adn there were a ton of tricks to charging and conditioning, because even .1v difference in a battery pack or 5-6 seconds life made a difference in winning/losing.
    We did dead shorting on packs, but you had to link each cell individually or there are side effects. Also there were battery "zapper" devices to get a little extra charge out of a battery pack. The results didn't last very long, only a few charges. A lot of people thought it shortened the overall lifespan of the batteries also.
    Usually when a battery pack dies, really you're only losing one cell out of it. It would be nice if it were easier to open/access the nicad packs and replace the bad battery.
    Feb 2009
    Whittier, CA, USA
    512
    I recently tried it on 4 18 volt battery packs. Tried it with 36 volt strung together battery packs, auto battery charger, MIG welder. A little better for a couple of charges, then back to useless.
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    Feb 2011
    Northern Lower Michigan/Troll
    196
    I tried it on my Hilti's. Loved my Hilti stuff but it would go through batteries, and replacements for Hiltis are pricy. Didn't work.
    I switched to Makitas because the whole unit costs less than a Hilti battery set.
    Chris Hatfield is offline Former Member (by the member's request)
    Aug 2010
    380
    I'd save the time and upgrade to the Lithium, if its available for your tools. I did, and I'm not going back. I still have my original two Ni-Cds that I keep around, but I haven't bothered to charge them in months. They'll be relegated to the fan and radio once spring rolls around. The actual tools get the Lithiums.
    Jan 2011
    charleston wv
    8
    i tried it on some milwaukee nicads and it didnt make no difference at all. packs were still weak and charge didnt last no longer. personly i think its a waste of time and the dangers involved arent worth it and my spelling sucks right now.
  1. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  2. Talk about "Call back the past"
    Last Post: 08-22-2013, 02:59 PM
  3. A new "tool" and back to the woodshop
    By Dan Gonzales in forum Off Topic Discussion
    Last Post: 09-15-2010, 06:15 PM
  4. Once you go "GREEN" you won't go back
    By randy street in forum Off Topic Discussion
    Last Post: 07-05-2007, 06:53 AM
