Brian Altop
- Tacoma, WA
My sled is out as you can see in the photo, well their is a gap at the front of the cut here(1st photo). This is after I cut off the end of the MDF with both top and bottom of board being parallel with each other. I just flipped the cutoff piece over (top to bottom, cut still to cut) and butted it back up to see if it lined up perfect or not. I think when I had my saw repaired and then re-aligned the blade to the miter slots is where I'm getting this discrepancy now. Did the cherry move a little?
The sled is cherry with purple heart in the corners and BB as the base.
Everything is glued together. I thought about sanding the back fence a little, but don't know if I could get it exact enough.
Thought about kicking the runners on the bottom of the sled over a tad...
What are your thoughts?
I need this to be exact, if need be, this weekend I'll just make a new sled.
Thanks!
Brian
Thanks!
Brian
