Results 1 to 4 of 4
Thread: Freud Router Table modification
    Jan 2011
    Tacoma, WA
    274
    I got this Freud Router Table on sale with 3hp router and all. I hated the three position fence though. I also hated the inserts. Other inserts that I could find would not fit it. The inserts that were provided were either proud of the table or just under so I made my own out of lexan.
    For the track I just took a track and cut it in half, then used my router and ran it down a straight edge to route out the table for the track to fit in. I glued and screwed the track down. My only mistake was the over cut at the front as you can see. i will fill that in with something a little later. Works great and I don't have to unscrew the adjustment knobs to do gross adjustments.
    All total cost me about 20 dollars and 30 minutes.
    Brian
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    Looks like a good modification. Bondo works great for filling odd holes in melamine-covered MDF. Epoxy also works.
    When I made my drill press table, I messed up the slots (repeatedly), but I had a lot more space to fill, so I used wood.
    17,475
    thanks for the answer to a hindrance i have on mine,, i know how to fix it thanks to you brian
    12,262
    Thanks for his Brian, now i trust my instincts more. I always looked at that table at the HD and thought something aint right. Glad you were able to tune itup.
  1. Freud 1700VCE router
    Last Post: 07-18-2012, 12:50 PM
  2. FS: Freud 5-piece Router Bit Set (NIB)
    By scott spencer in forum Old Ads
    Last Post: 01-02-2010, 12:48 PM
  3. Freud 45 degree router bit
    Last Post: 03-17-2009, 01:20 PM
  4. Freud Router
    By Al killian in forum New Tools
    Last Post: 01-09-2008, 10:22 AM
  5. Replies: 17
    Last Post: 02-03-2007, 03:02 PM
