Results 1 to 10 of 16
Thread: Lion trimmer......
    Feb 2011
    Northern Lower Michigan/Troll
    196
    Lion trimmer......
    I recently aquired a NOS Lion Trimmer and just did my first job with it. I was doing a coffered ceiling with African Cherry/Makore and ran into some issues, was wondering how you fellows with a trimmer dealt with them. I used it for the small moulding that go in between the beams.
    #1
    African cherry is fairly hard, but no harder than say white oak I would say. It does chip easy though. The problem that I had was that the gear would skip even on the lightest cuts, say 1/64". Then you had to run the knives out and reset the gear where it needs to be. I temporarily fixed the problem by putting some sawdust in the gear rack to raise the rotating gear.
    I was thinking about pouring some molten soldier in the bottom rack to raise the gear wheel for better bite on the top rack. Any problem with that?
    #2
    Again, this may have to do with the hardness of the wood used, but I had a hard time keeping the fences at 45 degrees. I had the stop adjusted perfectly. and the thumbscrew tight, by hand, but it would push the springloaded stop down and slide back toward 90 degrees.
    Are these not really suited to very hard wood? I played with it in the shop with poplar and did not see these problems.
    Is there a way to adjust the rack to rack distance that I am missing?
    I knew that this was its virgin run, so I made extra mouldings, and I did get the job done. It worked very well other than these small problems. The blades are very sharp by the way, so that was not an issue. I figured that out when I caught my hand on the point of the knife when the round gear was not set right and sliding it back too far.
    This wood chips bad with a chop saw on miters, so it actually worked out better than power tools. I mitered because there was not enough money for coping, and this stuff does not cope well anyway.
    Any input would be great as this is the only Lion trimmer I have ever seen.
    The other Larry
    11,833
    Larry, only a few of us know everything.
    It would be helpful to explain: "NOS" and "lion trimmer".
    What are they?
    For your situation, pics would help a lot, a real lot.
    17,472
    frank its a mitre trimmer,, you make a cut witha chop saw for instance then trim to precise fit..its a gillentin style tool..
    11,833
    Hokay. My father had one. I always thought it was a torture thing for removing fingers.
    Dec 2009
    Emporia, KS
    111
    NOS = New Old Stock
    Ike
    5,321
    I've had mine for maybe fifteen years, and have cut everything from pine to Macassar Ebony with it, and have experienced no problems like you describe.
    Are your knives really sharp? Dull knives will require more pressure, and might be the cause of your gear jumping a tooth. If the knives are sharp, maybe shimming up the lower rack will work. Not sure about solder, though. Can you disassemble it and put some brass shim stock under it?
    I've never had the fences move, either. nearly all the pressure (when cutting) should be pretty much on the pivot point, and not on the outer edges of the fence. I can't understand why they'd move.
    BTW, don't trust those fence stops - They go out of adjustment easily. Use a good quality drafting triangle to set the fence accurately.
    Feb 2011
    196
    This unit was brand new, original sharpening, never cut a piece of wood. They were as sharp as I could get them myself. No nicks. It was very sharp.
    The gear thing will be easy to fix, not like I can call the company up. Just wondered if it was common. If it was one of the last ones made maybe the molds were getting messed up and no one cared?
    I'll play with it some more when I get my shop set up again. On the job site was not the place to fix it.
    Thanks, Larry
    Jan 2011
    Tacoma, WA
    274
    Can't remember where I saw one of these...I thought I saw one brand new, does someone still make these? oh well, tough getting old and not remembering things.
    Is this basically a lever operated shooting board or are the shooting boards a diff type of animal all together?
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    Jan 2011
    Tacoma, WA
    274
    Ok, here we go!
    http://www.lionmitertrimmer.com/
    Maybe I'll have to look into one of these...Must - have - new - toy!!!
    5,321
    Quote Originally Posted by Brian Altop View Post
    Ok, here we go!
    Interesting. I thought the original company was out of business. Maybe they just forgot to take their website down?
    There are TaiChi copies still being made and sold, though - and I'm told that parts (like blades) are actually interchangeable with the originals.
  1. Lion Roar
    By Paul Douglass in forum Flatwork Project Showcase
    Last Post: 04-09-2015, 04:58 PM
  2. Mt. Lion painting is finished
    Last Post: 11-24-2012, 06:21 PM
  3. Mountian lion
    Last Post: 11-22-2012, 03:24 AM
  4. mountain lion
    By Virgil Huffman in forum Flatwork Project Showcase
    Last Post: 05-12-2010, 05:21 AM
  5. Mountain Lion in LA
    Last Post: 10-12-2008, 03:17 PM
