Results 1 to 10 of 11
Thread: Door hinges
    Nov 2010
    Richmond, MI near Port Huron
    64
    Door hinges
    Hi There
    I normaly stalk the wood turning areas but I have a question.
    I cut a door from the house into the shop/garage. I know could be a mistake with all the shavings and saw dust but it's been handy this year.
    Any way the door it self is leaning and bumps the frame when it closes. I'm sure it didn't when I first hung it. When I built it, yes not pre hung, $5 yard sale door, I noticed the doors at the big box didn't have the hinges recessed in the frame so I didn't either. When it started bumping I cut in the top hinge with no help. It appears the hinge is either very sloppy or the metel is not thick/sturdy enough to hold the door vertical. Any comments would be helpfull. Thanks
    Guy a picture would be helpful.
    Jun 2010
    3,220
    Guy, I'm not sure you've had a proper WELCOME TO THE FORUM!!
    AKA The Rookie
    17,475
    welcom guy to the forum and swear someone left the gate open here ,, another guy from michigan yeahh,,
    9,077
    I thought we reached our MDL already (Michigander Density Limit). Welcome Guy. Doors can be a bit of an art form. What did you use for a header in the frame? 4 x 6 is good, bigger is better in our flimsy California homes. Any chance your frame has canted?
    Nov 2010
    64
    door hinges
    When I look at the door in the frame while it's closed, the gap between the frame directly above the upper hinge is wider than the gap directly below the lower hinge. I'll recheck the hinge side of the frame for plumb and check again that the screws are all tight.
    I'm out of camera batteries [the tightwad in me won't buy with out a coupon] I'll get some tomorrow and try and get some pics.
    My thinking is that the door is to heavy for only three hinges but it isn't reinforced for a fourth.
    Nov 2010
    64
    Sorry Hi everybody
    I'm Guy from Michigan. Way northeast of Detroit closer to Port Huron.
    Don't look to much different from my avatar just draw in a white mustache curling down.
    I am a retired electrician
    Started woodturning about 4 years ago.
    Thanks for the help
    Dec 2009
    Emporia, KS
    112
    Quote Originally Posted by Guy Bratt View Post
    Guy,
    Put a couple of screws in the top hinge long enough to go thru the jamb and into the stud behind it. (Deck screws will work.) You should be able to tighten those enough to close the gap between the top of the door and jamb. It should also open the gap where your door is hitting.
    Ike
    Nov 2010
    64
    Hinge pics
    Ok here's the top and bottom spacing. Every thing is plumb, square and tight.http://i1231.photobucket.com/albums/...t/DSCF0199.jpg
    http://i1231.photobucket.com/albums/...t/DSCF0200.jpg
    Jul 2007
    Liberty, IN
    25
    Do as Wayne said & put a couple of screws through the top hinge into the stud.
    Are there shims between the stud & jamb at the hinge locations?
  1. screw door hinges?
    By Doug DeVore in forum General Woodworking Q&A
    Last Post: 09-19-2011, 10:47 PM
  2. Hinges one more time please
    Last Post: 09-07-2009, 05:55 PM
  3. hinges...
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 09-04-2009, 07:01 PM
  4. Hinges
    By Douglas Jones in forum Old Ads
    Last Post: 07-17-2008, 04:08 AM
  5. My Take on Wood Hinges
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 02-06-2008, 04:41 AM
