Results 1 to 10 of 17
Thread: Mission Coffee Table
    Hamilton, New Zealand
    57
    Thumbs up Mission Coffee Table
    Its been a long time coming. For the past year or more I haven't had much time for a bit of shop work.
    This mission style coffee table was started back in May/June of last year. Weather and work has played a large part in this table being finished as it bowed after I glued up the top.Even though the timber was dry and had been for years it soaked up enough moisture due to an extended rainy period last winter to make the top bow. It hasn't been until a couple of weeks ago that I was convinced it has settled back as much as it was going to.
    The top is made from a small slab of Matai, and sawn into boards 125mm wide by 35mm thick. The underside of the table(frame) is all made from recycled rough sawn 100 x 50 mm Rimu.
    The top is coated with 4 coats of Matt finish poly and all the framing is simply oiled. Heart Rimu is extremely hard and sands to a fine finish very well. A clear polishing oil is used and this makes the color and texture of the timber darken and pop.
    As you can see from the photos depending on the direction of light the table changes color.
    Attached Thumbnails Attached Thumbnails DSCF6268.JPG   DSCF6269.JPG   DSCF6274.JPG   DSCF6275.JPG   DSCF6277.JPG
    Err ... Me, make a mistake .. Never
    http://akiwiretrospective.blogspot.com/
    Nicely done...
    10,604
    Very very nice. Looks like you have nice shop space as well
    57
    Thanks Don. It would have been nice if I had had sufficient timber in the slab to color and pattern match the top a little better. Unfortunately the slab was quite small so there wasnt a lot of "meat" in the center to work with. I'm pleased with the color though. I was worried it would be too dark.
    Jan 2011
    3,798
    Very nice!
    Looking good. I think your coloring came out fine. A nice solid looking piece which is a good appearance for a coffee table. It kind of anchors the room for me.
    Sep 2007
    Plainwell, Michigan
    4,857
    Great looking coffee table Ralph That Matai sure is some good looking wood
    Constantine, MI
    7,890
    Ooooooo, I like. Nicely done!
    www.wrworkshop.com
    12,251
    +1 on what they all said. I really like mission style.
    30,014
    Very well done, Ralph.
  1. mission coffee table - considering options
    By Art Mulder in forum Designs, Plans and Sketches
    Last Post: 11-02-2014, 12:55 AM
  2. Mission Style coffe table
    Last Post: 08-22-2009, 01:29 PM
  3. Mission Style End Table
    By Dave Haynes in forum Flatwork Project Showcase
    Last Post: 07-20-2009, 07:11 PM
  4. Coffee table
    By Jeff Horton in forum Flatwork Project Showcase
    Last Post: 05-07-2007, 01:19 AM
  5. Mission End Table
    By Sean Wright in forum Flatwork Project Showcase
    Last Post: 03-29-2007, 01:27 AM
