cleat-that is the way to go.
Since the mounting surface will be small, I wont be able to hit 2 studs in the wall.
Im thinking more along a wide cleat that I can bolt 2 1/4 inch bolts on top and below because Im quite sure 2 bolts would hold the weight and keep the cleat level.
Ive seen wide cleats and if they are cheap enough for a 6 inch piece, Ill go with metal. Or Ill just make one out of plywood.
toni-my first thoughts were to use tensioning wire, the thick 1/8 inch cable stuff, but getting tension on that on both ends would require too much hardware and I didnt want to bulk up the ends nor spend an extra 25 dollars on all the extra hardware.And then came the shine question. The chrome coated chain reflects light and that appealed to me more than a flat type of surface color.
