Larry Edgerton
- Northern Lower Michigan/Troll
When I am cutting sheet goods I set up some saw horses and lay out all my cuts before I even look at the saw. Then I will do what cuts I can to reduce the size of the materials with a circular saw ( skill saw). That way I am not dancing with huge sheets off the end of the table saw. Just because others do things a certain way doesn't always mean it is the right way or the safest. It comes down to what you feel comfortable with.
QUOTE]
This is something I do as well on the jobsite, and I have a delta contractor with unifence as well for site work. Even in the shop with my large saws I break pieces down doing the easy cuts first.
For example say I am cutting sheet goods for upper cabinets. I need 4- 11 1/4" rips out of a sheet. First I will rip the sheet down the middle as that is an easy cut, get my good edge, and then rip my 11 1/4" strips out of that using the good center cut at the fence. If you try to first cut a narrow strip off of the edge it is more and harder work, and will be less accurate.
Take the time to envision what you need out of your sheet goods and take time to think about the sequence of cuts and it will save you much physical exersion. Even with a large saw and infeed/outfeed tables sheet goods can be hard work if you fight them.
The other Larry
