Results 1 to 10 of 21
Thread: Discovered the curved dado today
    Chris Hatfield is offline Former Member (by the member's request)
    Aug 2010
    380
    Making a caddy for my ROS and paper, and the dados were coming along fine until the last one. My fence was too far over, and I was pushing too far away from the blade. Voila, a curved dado.
    Got lucky, it was only a 6.5"x5.5" of 1/2" ply. Got a little cut on my stomach.
    Now that'll wake you up but quick. Now go change your shorts ;-) On the upside, those are nice clean looking dados.
    Catalunya
    4,632
    That must have made a terrifying noise. Glad the results were not serious.
    Best regards,
    Toni
    17,471
    toni. the only noise is the ones that yu make after you get hit or it hits something else...
    Jun 2010
    3,220
    Chris, can you explain in little words exactly what happened?
    AKA The Rookie
    Aug 2010
    380
    Sure. I set up a sacrificial fence for the dado stack and was making the cuts from the top to the bottom, moving the fence over 1.5" each time. On the last one, the fence was too far over from the blade. I was also pushing on the piece with my stick between the blade and the fence. The piece rose up a touch on the blade and cartwheeled back at me. It was a cheap lesson to learn.
    I finished the cut on that one and the opposite piece by readjusting the fence closer to the blade an turning the piece around, which I should have done in the first place, or used a featherboard on the left side of the blade.
    May 2009
    Poway, CA, near San Diego
    174
    That piece is way too narrow to use with a fence. Better might have been using a miter gauge and a longer board. Cut off the smaller piece after dadoing.
    Glad nothing bad happened,
    Bob
    30,008
    Quote Originally Posted by Bob Meyer View Post
    Bob
    Another approach would be to use a push block (like the Grrripper) instead of push sticks. I pretty much refuse to use push sticks on a tablesaw anymore, because they don't offer nearly as good of control of the piece as the Grrripper does.
    Glad you didn't get hurt any worse than you did, Chris.
    Aug 2010
    380
    That's on my wish list. For sturdiness, it was fine until that last cut.
    13,357
    For dado cuts, I use the same sort of rubber backed hold down that I would use on a jointer for making the cut...
    Cheap, keeps the piece flat on the machine, and keeps your hands away from the blade.
    http://www.amazon.com/Grip-55214-6In.../dp/B003MBPRYS
  1. I may have discovered the 8th Wonder of the World
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 03-27-2015, 03:31 AM
  2. I discovered the best way to cut Polystyrene...
    By Art Mulder in forum Off Topic Discussion
    Last Post: 12-02-2013, 03:56 PM
  3. i think i just discovered.......
    By Rich Soby in forum Off Topic Discussion
    Last Post: 06-03-2013, 12:36 AM
  4. Discovered something new
    Last Post: 06-26-2010, 10:29 PM
  5. I Discovered Sharp Today
    By Brian Gumpper in forum Neander Woodworking Q&A
    Last Post: 11-28-2006, 01:40 AM
