Results 1 to 10 of 11
Thread: ??? For cabinet makers ???
    Question ??? For cabinet makers ???
    How in your expereince, is the best way to glue up shaker rail and style kitchen cabinet doors so that no glue squeezes out of the corner joints on to the panel and there by making your door a mess? I have all my parts ready to start to assemble my doors and this problem has been vexing me and I have not been able to figure out how to get good clean glue ups.
    Thanks for any help and suggestions.
    Tom...
    Orem, Utah
    935
    I've never done it myself, but I seem to remember reading that you can dry fit the parts, put down blue painter's tape right next to the joints, then pull everything apart and reassemble with glue.
    The squeeze out should end up on the tape, which you can pull off once the squeeze out dries (or at least skins over).
    Oct 2009
    Dennison, MN
    512
    Just don't glue it all the way to the inside edge.
    If its squeezing out, use less glue.
    I also assemble the door with the rail hanging past the end of the stile a bit, then pound them flush once there's some clamp pressure. That seems to help somewhat too.
    "Do, or do not. There is no try."
    -Yoda
    Two things
    1. don't use so much glue
    2. put the glue on the mortises only
    Catalunya
    4,632
    I'm not so sure about the type of door of you are talking about but I have always seen that in frame and panel doors or sides, the panels are NOT glued to the frame to allow for wood movement
    Best regards,
    Toni
    Feb 2011
    Northern Lower Michigan/Troll
    196
    Q tips.......
    3,132
    Quote Originally Posted by Karl Brogger View Post
    I agree with all of the above.
    N.E. Arkansas
    374
    I put together a lot of doors and what we do is to apply glue to the tenon with a small brush and apply a wet coat but not enough to make it runny. Also the glue usually will squeeze out onto the panel at the corner so we do not apply glue to the last 3/4" or so. The glue will migrate a little into that area anyway once you apply some clamp pressure. Likely you may be using a bit too much glue, cut back a little and watch where you apply the glue.
    I once heard that cats and women will do darn well what they please and that men and dogs would do well to accept it and just go on.
    Oct 2009
    Dennison, MN
    512
    You're always going to have a door here and there with glue in a corner. Either a damp rag while the glue is still wet, or wait for it to dry and use a small chisel.
    -Yoda
    Thank you one and all...
    I had not done any yet, hence the question for advice before I tried it I followed your good advice and the doors went together just fine and no squeeze out in the corners.
    I used panel buddies to keep the panels centered and since they are foam rubber, they will depress some what if the panel wants too move. These are quarter sawn white oak vaneer on what looks like masonite hard board core. Beautiful stuff. Had to do a small amount of fill in the joints, but all is well, when I get the final sanding done tomorrow, I will snap a few pics and post for your enjoyment.
    Thanks again.
    Tom...
  1. FYI PEN MAKERS
    Last Post: 03-12-2016, 11:25 AM
  2. for you cabinet makers
    Last Post: 12-29-2010, 08:32 PM
  3. For you cabinet makers
    Last Post: 12-28-2010, 06:56 PM
  4. Knife makers
    Last Post: 04-21-2008, 01:58 PM
  5. for knife makers
    By Frank Fusco in forum Neander Tool Questions and Show & Tell
    Last Post: 03-03-2008, 08:00 PM
