Results 1 to 10 of 26
Thread: Off Center Eccentric Turning
    Jun 2010
    3,220
    Hi there:
    I'm not a turner, but I'm fascinated by the eccentric turning. What I don't understand is, if the piece is mounted off-center, and you hold the tool in the same place, doesn't it only touch the piece in one place? because the tool isn't touching the piece continuously?
    I'm wondering if some of the eccentric individuals here could explain it to me.....? I've tried to watch some videos on YouTube, but they're mostly in foreign languages (that I don't speak).
    thanks
    AKA The Rookie
    Los Angeles, CA
    2,668
    Cynthia, I have only turned one offcenter item. Well, if you don't move the tool then the answer to your question is YES. But, in reality you have to keep moving the tool until you make contact and keep cutting. It is a strange feeling when you turn offcenter as you also see a ghost outline of the piece.
    NH
    4,005
    Cynthia in this thread http://familywoodworking.org/forums/...ad.php?t=22621 post 6 in one of the pics you can see where I marked the the handle in black. That is the only place the tool cuts when the work is off center. It starts out being a very short cut and as material is removed it get longer.
    Stupid hurts.
    Orem, Utah
    935
    I hope this diagram doesn't confuse the issue by starting with an oval workpiece:
    I'm trying to show how, if you present the cutting tool at position A you will indeed get an intermittent cut. But by the time you work down to position B you're cutting all the time and forming a cylinder (the blue circle), at least at that particular point along the length of the workpiece.
    Aug 2008
    Reno, Nv
    3,632
    Cynthia..please start turning. start turning now...avoid the delay...just do it. Go buy a little Jet or Delta and make something...please???
    NH
    4,005
    We have cookies.
    Stupid hurts.
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    When you come down Cynthia I will show you some books that explain it real easy. I might have something set up to show you how it is done. It is easier than it sounds ad yes you seem to have lots of questions about lathes You can feel that pull can't you The vortex is calling you and remember we have cookies.
    12,251
    Oh boy i feel the need to get hold of glass man Brian and whisper some words in his ear. You aint never getting those bookshelves if you touch the spinny stuff. Stick with flatwork.
    Jun 2010
    3,220
    Chuck, why does it have to be oval?
    No worries, Rob, I'm just asking some questions is all..........I am curious though, what if someone wanted to buy a small lathe.....not me of course....just to see if they liked turning or not.....what should they buy?.....
    Quote Originally Posted by Drew Watson View Post
    thanks Drew....we'll have a busy day!!
    AKA The Rookie
    13,360
    Cynthia, check any axe handles or hammers you have. You'll find they typically have oval handles. Just more comfortable for the hand to grip than a perfectly round one.
  1. Off Center Turning on the Cheap
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 10-24-2013, 05:00 PM
  2. Inexpensive safety center/dead center
    By Mike Mills in forum Turning Tool Questions and Show & Tell
    Last Post: 01-25-2012, 11:50 PM
  3. Eccentric Baltic Birch Plywood Bud Vase
    By Jim Krager in forum Lathe Project Showcase
    Last Post: 08-09-2011, 09:23 PM
  4. Pendant Turning with the Richard Joiner Eccentric Backing Plate
    By Vaughn McMillan in forum Tips and Tutorials
    Last Post: 08-19-2010, 02:41 PM
  5. Eccentric Goblet
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 06-27-2008, 01:56 PM
