Results 1 to 4 of 4
Thread: The gates are hanging
    Sep 2010
    Woking, Great Britain
    22
    This weekend, I found some time to weld the shoe to the bottom hinge, the shoe is a 1 ˝ foot long piece of U profile that will fit around the bottom joist of the gate
    DSC_2518 by mcluma, on Flickr
    The hinge above is the wall plate which is going to be the top hinge
    I will admit I am not the world’s best welder, but was not disappointed with the final result (of course I ran out of welding wire, and had to get some new one, (I just got a bit crazy and didn’t now I was using that much wire)
    Below you see the shoe fitted to the bottom of the gate, 6 screws will hold the gate in the shoe, the bottom got painted before fitting
    DSC_2552 by mcluma, on Flickr
    And here you see the final result of all the hard work, the gates are finally fitted
    DSC_2557 by mcluma, on Flickr
    This is the back of the gate with only one coat of paint on
    AND THE FRONT
    DSC_2566 by mcluma, on Flickr
    Really happy with the final result, the opening between the gates is 12mm, i had calculated for 10mm, so all in all really happy
    What remains to be done is:
    Electrics / Intercom / lights / wooden gate styles / etc
    12,245
    Good job there Chris. You been hard at work again i see. Those gates a beautys.
    Dec 2008
    Santa Claus, In
    4,779
    Looking good Chris
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    13,427
    Are you at Cynthia's house???
    Looks good Chris, quite a project you got going.
  1. Fence Gates
    By Rob Keeble in forum Carpentry and Construction
    Last Post: 08-05-2011, 07:10 PM
  2. Wall Hanging - IT'S FINISHED and not a wall hanging anymore!!
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 09-21-2010, 03:43 PM
  3. Shop Vac Duct and Gates
    By glenn bradley in forum Shop Tours
    Last Post: 08-09-2010, 10:19 AM
  4. Metal blast gates????
    Last Post: 04-09-2007, 03:56 AM
  5. A Tori and a new gates
    Last Post: 11-11-2006, 11:07 PM
