Results 1 to 6 of 6
Thread: Wiring your shop for 220
    5,321
    There are always a lot of threads about electricity, particularly 110 vs 220. I did some research and have found the definitive answers to all of your questions. So, if you don't understand electricity for your shop, be sure to read this. (Please do not try this at home ;-) )
    220 Volt Wiring Explained:
    I think its time for me to explain about 220 current and why it is so different from 110 volt service. First of all, it's twice as big.
    Secondly, it'll shock you more. Outside of that, 220 is really two 110 volt lines coming to your house from different parts of the globe.
    The up and down 110 comes from the northern hemisphere, and the down and up version comes from below the equator.
    Without trying to get technical, it all boils down to the direction water flows when it goes down the drain. In the top of the earth, it goes clockwise, while on the bottom of the earth it goes counter clockwise. Since most electricity is made from hydro dams, the clockwise flow gives you an up and down sine wave, while the counterclockwise version gives you a down and up sine wave. Between the two, you have 220 volts, while either individual side only gives you 110 volts.
    This is partiularly important to know when buying power tools- which side of the globe did they come from? If you get an Australian saw, for instance, it will turn backwards if connected to a US generated 110 volt source. Sure, you can buy backwards blades for it, but that is an unnecessary burden. Other appliances, like toasters cannot be converted from Australian electricity to American electricity, without horrible results. I knew one person who bought an Australian toaster by mistake and it froze the slices of bread she put in it.
    If you wire your shop with 220 and accidentally get two US-generated 110 volt lines run in by accident, you can get 220 by using a trick I learned from an old electrician. Just put each source into its own fuse box and then turn one of the boxes upside down. That'll invert one of the two up and down sine waves to down and up, giving you 220. DO NOT just turn the box sideways, since that'll give you 165 volts and you'll be limited to just using Candian tools with it.
    12,256
    Los Angeles, CA
    2,668
    Such great timing. I am exploring options to add 220v to my shop.
    Dec 2008
    Santa Claus, In
    4,779
    Quote Originally Posted by Mohammad Madha View Post
    No reason not to now. You have all the info you need
    30,017
    Jim, you are so full of information*.
    Kudos to you, fine sir.
    * Didn't say it was good information, just that you're full of it.
    10,604
  1. Wiring question!
    By Barry Stratton in forum Carpentry and Construction
    Last Post: 06-23-2014, 12:56 AM
  2. Wiring for my new DC.
    By John Pollman in forum Off Topic Discussion
    Last Post: 04-24-2013, 01:58 AM
  3. Switch Wiring
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 05-10-2012, 04:51 AM
  4. Shop wiring upgrade
    By Ken Cook in forum Carpentry and Construction
    Last Post: 02-23-2012, 05:43 AM
  5. Shop Wiring Costs
    By Tommy Squires in forum Carpentry and Construction
    Last Post: 04-07-2007, 07:43 PM
