larry merlau
- Delton, Michigan
have others had this and how do you get rid of it and will it cause finish problems?
Hi Ya Larry
Any chance acetone would do the trick. I know you said DNA but i think they different solvents.
My guess is the stuff in the vinyl is oil based i was thinking perhaps the acetone would lift it.
Tom you know i always wondered about those space ball thingys. They made of rubber and over time certain rubber does degrade.
Larry, if that's my box you're working on, I want you to start over.
I dont use the rubber or plactic pads. I have replaced them with cork with I glue on with ca clue and when they get worn it scrap them off and replace them.
