Results 1 to 10 of 10
Thread: Any elevator people on here?
    Feb 2011
    Northern Lower Michigan/Troll
    196
    I was hired today to put an elevator in a house. Don't know a thing about it. So I have some research to do but was wondering if by some stroke of providence there was an elevator expert on here?
    Probably about a one in 500,000 shot, and another 1 in a million that that person would read it, but there you have it.
    The other Larry
    Jun 2010
    3,220
    Larry, I know a little bit about it.
    My dad put an elevator in his 3 story weekend house. This is how it went.
    A) He hired a contractor
    B) The contractor hired the elevator people
    C) The elevator people gave specs to the contractor.
    D) The contractor had to get permission from the locals--it's some kind of gated community.
    E) Then the contractor had to make some modifications to the roof line and to the lowest floor--I think a few feet had to be dug out.
    D) The elevator people installed it.
    E) It cost a fortune.
    And that's all I know. I hope it helps.
    AKA The Rookie
    I used to build motor controls for elevators and I got to tell ya unless you have expierance don't do it, Hire it out. It is very very tightly regulated but the state.
    Feb 2011
    196
    I'm not going to install the elevator, that will be sub'ed out of course. I have to pick an elevator, arrange all the permits, and prep the house for the elevator, supervise its install and then button it up.
    You need to make some calls to companies that do this. I have oversaw the installation of a few and each type has it's own specs. for the shaft size, where the controls go and the access they need to work on them along with any ventilation for cooling the equipment. You will also need to get phone service to it.
    Dec 2008
    Portland, Oregon
    1,898
    And then there is the Elevator theory of traffic jams: If you didn't have elevators, you wouldn't have these multi story buildings (would you walk up 60 or 100 flights of stairs to go to work) everything would be more spread out instead of everyone trying to get down town at the same time. So next time you're stuck in traffic, blame Mr. Otis. Just a theory based on unscientific data.
    Jesus was a Woodworker
    Feb 2011
    196
    Quote Originally Posted by Alan Bienlein View Post
    Yes, I realize this, but I was hoping to draw from experiance and find out what companys for example are of good value, and what ones to avoid. I am also curious about vacuum tube elevators, but I have not ever seen one. I live in a rural area, and avoid citys like the plague, so not a lot of exposure to this. This will be a retro fit, and the customer is a long time loyal customer that want me to handle it.
    30,008
    Dover (now ThyssenKrupp), and Otis are the major players. My suggestion would be to find out who your elevator sub works with (or for) and go from there. The sub should be able to give you the heads-up about any unique requirements.
    My brother-in-law's brother-in-law is a retired elevator guy. (He worked for Dover, then ThyssenKrupp.) From talking with him, it seems pretty much every elevator installation is custom in some way or another. Since it's a pretty specialized field, I'd think it would make sense to have the elevator people involved in specifying the requirements.
    Well Larry the only ones I know of are the ones Vaughn mentioned. I can tell you from experience that if something isn't right they will not proceed with the job so make sure you ask alot of questions and right it all down. They usually have a written sheet of requirements that need to be met to use as a checklist. Every situation is different and depending on the location the elevator goes in will dictate the type of elevator you can install.
    Honolulu, Hawaii
    1,103
    Larry, I have had a few elevators modernized in some high-rise buildings I managed, but never a completely new installation
    As mentioned, + just a few.
    OTIS (was the Cadillac of elevators)
    Thyssen-Krupp (Formerly dover)
    Schindler Elevator
    Mitsubishi Elevator (about the highest class nowadays)
    Kone Elevators
    Depending on how many stories the house is you may go with a hydraulic unit instead of cable & hoist machine (with counterweights) Hydraulics need a deeper pit for the lift but the pump unit can be placed on ground level. A cable & hoist will need a pit under the cab, and a machine room above for all the lifting machinery and controllers. A hydraulic may be the best way for a house.
    HTH
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
  1. for you bbq people
    By allen levine in forum The Cook Shack
    Last Post: 06-23-2015, 01:02 PM
  2. How can people do this
    By Bob Gibson in forum Off Topic Discussion
    Last Post: 07-05-2014, 02:23 PM
  3. Swamp people
    Last Post: 07-23-2011, 01:52 PM
  4. The people here are the best
    By Jay Caughron in forum Off Topic Discussion
    Last Post: 06-15-2010, 11:13 PM
  5. Nashville and TN people, my hat is off to you!!
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 05-20-2010, 08:58 PM
