Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Slow Speed Grinder!!!
    15,815
    Oh Yeah Baby!!
    Got the slow speed 8" Wood Craft grinder today!
    There it sits, 18,150 yen to me ($150)
    Wheels mounted up, and start it, MAN ALIVE, did I buy a paint shaker by mistake
    OK, off comes the wheels, and I'll check the shafts........... yep, zero run out. Without the wheels, the grinder runs nice and smooth
    The problem is with the cheapo wheels, something that I expected, but not nearly this bad...
    OK, I have to clean up the wheels, but first, I want to make sure the other parts are good, the washers are ground, but not very well, so I put them on the scary sharp stone and make them shinny flat.
    Now on to the wheels, I did my best to make the stone flat on the front surface, but with all the vibration, it was nearly impossible............
    I got my handy X-Y drill press vice, put it in the bench vice, then clamped the diamond dresser in the vice, and brought up the grinder
    I put some pencil marks on the wheel and had a go....
    The results were very good, the amount of vibrations is down, WAY down!!
    Now I need to figure out how to dress the inside of the wheel, then make some new jigs for sharpening......
    switch sides with the wheels right to left, still spinnin` the same direction but opisite face exposed......
    15,815
    Yeah, I was thinking of doing that, but I'm worried that the washers etc. are not exactly true, so who knows if I'll just make it worse....?
    Anyway, the result is still WAY better than it was out of the box, that is for sure, and the next time I get an order from the US, I'll be sure to get some better quality wheels, and I might even get that balancer thing from Oneway....?
    Oneway Percision Balancing System Review
    Anyone have this system?
    Looks like I'd have to buy new wheels to use it, as it says they have the flange for various sized shafts (my grinder is 5/8") but the wheel has to have 1" holes.....
    I'm going to be teaching myself how to freehand grind too!
    Charlotte, NC
    1,487
    Cool Stu, Once you get it balanced, you will like that grinder (at least I do!).
    15,815
    I have no doubt about that Ed, I can't wait to have a go at hand sharpening!
    11,899
    When I bought my 80 grit blue wheel from Woodcraft, the first one was very bad, like you describe. I called and they replaced. But during the call the lady told me that out of round/balance/whatever wheels were very common. My replacement wasn't perfect but I kept it.
    I always like to see your 'pictorials'. Stu. I appreciate your taking the time to take, post and give explanations that go along with the pictures.
    Thanks .
    George
    Eastern Panhandle of West Virginia
    103
    Thumbs up
    Nice approach Stu, Like how you did that, thanks .
    Oh Yeah Baby!!
    Thinking about a project without ACTION is just DAY DREAMING .
    Steve Clardy Guest
    I've got the 6" Variable speed. Fair little grinder.
    My wheels were out of balance some. I just kept repositioning one of them till she ran smooth.
    15,815
    Well, I got the other one done, the 60 grit wheel, it was WAY worse than the 120 grit wheel.
    Half way though truing up one side, the whole grinder started bucking like a washing machine way out of balance, it it was not screwed to the bench it would have dance off the top for sure
    I shut it down and checked to see if I had something loose, like the opposite wheel etc.......... nope, could not find anything.
    Fired it up again, and it got worse, shook my work bench so hard it spilled my cup of coffee
    OK something is wrong here.................. Ah ha!
    Found it............. the bolts holding the base of the grinder to the body of the grinder had come loose
    took the grinder off the piece of 3/4" plywood it was bolted too, took the cover off the bottom and found three nuts almost off, just one was somewhat tight......... tightened them down and man, the whole thing ran a lot smoother..............
    Paging Alex Reid........... check yours when it shows up.
    Got the 60 grit wheel done, and the whole thing runs a LOT smoother, but.............. not nearly as smooth as the one I used at our last turners group workshop......... That was a VERY nice Baldor unit, with good quality wheels.......
    I guess I'm going to be getting new wheels and the Oneway balancing kit.
    I also want to make a vacuum attachment for keeping the grinding dust down. I'm thinking a hose to each side, through the wheel side cover, then to a 5 gallon pail, half full of water, the intake hose pipe will go under water, the outlet pipe will be well above water. This should keep the dust and grit in the water, and stop any errant sparks from going into my vacuum cleaner............ sound like a plan?
  1. Tormek LA-120 strop accessories on a Grizzly slow speed grinder.
    By Brent Dowell in forum Tips and Tutorials
    Last Post: 08-13-2013, 03:37 AM
  2. Jet Slow Speed and Rust
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 12-21-2010, 05:59 PM
  3. Jet slow speed jig
    By Bill McQueen in forum General Woodworking Q&A
    Last Post: 09-01-2009, 01:26 AM
  4. Jet Slow Speed Grinder Question
    By Bill Arnold in forum General Woodworking Q&A
    Last Post: 08-31-2007, 11:04 PM
  5. Speed............ slow it down?
    Last Post: 01-27-2007, 07:08 PM
