Results 1 to 10 of 10
Thread: Tiny Vix bits? AKA - How do you install tiny hinges . . .
    Long Hill Township, NJ
    467
    Hello:
    I'm setting up the hinges on my current entry in the box swap. If things go bad I have enough time to build another . . . .
    I'm using some very nice Brusso JB-101 Hinges that I have on hand. The issue I'm having is getting the screws to line up in the center of the "Bore". I get one set and the second doesn't go where I want it - twisting the hinge.
    Any tips? I'm currently waiting for the glue holding the toothpicks I filled the mis-aligned holes with to dry before I try again.
    Do they make TINY Vix bits or is there a better way?
    No pics - till the swap . . . .
    Cheers
    Jim
    Quote Originally Posted by Jim Mattheiss View Post
    Cheers
    Jim
    You get a pass on the pics because of the swap but take some anyhow...
    "Thereís a lot of work being done today that doesnít have any soul in it. The technique may be the utmost perfection, yet it is lifeless. It doesnít have a soul. I hope my furniture has a soul to it." - Sam Maloof
    NH
    4,006
    Stupid hurts.
    17,475
    jim i had a similiar problem, i used a 1/16 bit for the pilot hole and alitt bigger for the main area i used a round point scratch awl to postion the holes.. and yur right they like to move around..not sayun this is the best way but it got it done for me..but we know that OSB is tuff to drill striaght
    Woodcraft makes VIX bits down to a #3 screw size if that any help. The smallest Rockler had was #4
    correction I just checked and woodcraft has em down to #2...
    9,077
    I just take a bradpoint bit that fits the through hole (7/64" for example) and spin it backwards with my fingers. This self-centers the bit in the hole and the center spur marks the place to drll.
    13,363
    Brilliant! Simple solution and doesn't require any new tools...
    Dec 2008
    Santa Claus, In
    4,779
    And that is a bad thing
    10,604
    What a great idea
    Feb 2011
    Northern Lower Michigan/Troll
    196
    I use Vix bits. They are fast and accurate, but you must be very gentle with the small sizes that you are talking about. I you push them at all sideways while the bit is extended the drill bit will snap. Not really a problem, but it took me a couple of bits to figure it out. They are easily replaceable.
  1. 8 tiny reindeer
    By Don Orr in forum Flatwork Project Showcase
    Last Post: 12-24-2012, 07:58 PM
  2. Tiny Woodworking
    Last Post: 03-13-2012, 09:45 PM
  3. My Tiny Shop
    By Dan Pierce in forum Shop Tours
    Last Post: 06-25-2010, 10:04 PM
  4. My Tiny Shop
    By Steve Southwood in forum Shop Tours
    Last Post: 05-21-2010, 02:16 AM
  5. tiny router bits, jewelry anyone?
    Last Post: 03-18-2009, 01:52 PM
