Results 1 to 10 of 16
Thread: Spray on Adhesive that lets go when done...?
    15,811
    OK, I think that someone like 3M makes this kind of product, you spray it on, to say sandpaper, then stick the sandpaper to something, when done, the sandpaper just peels off.....?
    I guess a spray on Pressure Sensitive Adhesive.........?
    I think the one I want is #72, but when I look it up online, it says "Obsolete" on the 3M homepage.....
    I have the 77 stuff, but it is NOT PSA, as you need a razor blade to get that stuff off!
    I'm thinking of making my Disk sander disk out of thick MDF, and coating it with some sort of finish, then spray on the PSA and use normal sandpaper....?
    Anyone use this stuff?
    stu, just buy the psa discs.....i use 12"ers and they run about 4 bucks for 36 grit cloth backed.....
    if you`re dead set on an aerosol try auto body supply houses they might still have access? tod
    15,811
    Well one of the reasons I was thinking of using the spray and just sandpaper is the PSA disks here are about $16 each! If I buy in a pack of ten then they drop to about $12 each......
    Can of spray adhesive and some sandpaper......
    The Heart of Dixie
    4,268
    This might be what your looking for. It is low tack and might be to low for a disk sander. I use it for holding sandpaper to the granite plate for scary sharp. But you might want to search for low tack and see if that come up with something better.
    Custom built boats and Kits
    stu, try these guys? i don`t know if they`ll ship to japan?
    http://www.onlineindustrialsupply.com/?google-sandpaper
    15,811
    Thanks Tod
    Something like this huh?
    12" Cloth Sanding Disk Pack of 25 $85.95
    If they will ship to Japan, without shipping that is $3.44 a disc..........??
    Maybe Alex and I can go in on a few packs of discs.
    What are the recommended grits for a disk sander?
    Punta Gorda, Florida
    902
    Stu,
    I am pretty sure that this is what I have used: http://www.idealtruevalue.com/servlet/the-47236/Detail
    I don't know if you can get Duro products over there or not. I was using it on an old roll of 500 sheets that the glue had dried up on for a DA sander so it might not work as well with a disc sander, but it might.
    I still have a can of it so will test it today. I should let it set for a few hours and see if it still holds and will release.
    I'm with tod. If you can get the cloth backed psa disc for a reasonable amount I would go that route. They are tough as nails and will last much, much longer than regular sandpaper thus a greater cost is justified.
    Allen
    15,811
    Thanks Allen.
    I'm still waiting to hear back from the guys Tod linked to.
    902
    I just pulled off the sandpaper that I glued on with Duro and it was still holding good after six hours and easy to peel off.
    Hopefully tod's deal will work out for you.
    688
    Hey Stu,
    We use #77 for keeping sandpaper on glass. It comes off the glass easily with a little simple green. Maybe another approach would be to put a washable surface on your disc, maybe some formica or something...
  1. Recommended Spray Adhesive?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 01-25-2015, 05:06 AM
  2. Laminate adhesive
    By Guy Bratt in forum General Woodworking Q&A
    Last Post: 03-11-2013, 06:32 PM
  3. Spray adhesive?
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-21-2013, 03:38 PM
  4. Proper adhesive
    By Rex Bloem in forum Jigs and Fixtures
    Last Post: 01-18-2013, 05:25 AM
  5. Self adhesive rule that came with my table saw....
    By Craig Johnson in forum New Tools
    Last Post: 03-29-2009, 08:15 PM
