Results 1 to 10 of 28
Thread: Non woodworking project (pic heavy) updated
    New Springfield OH
    806
    My shop has been invaded. Nephew and I are completely redoing his 1800 Oliver farm tractor. Along the way its also getting a heart transplant. Getting rid of the original Waukesha 6 Cylinder gas engine (roughly 80 HP) and replacing it with a 1988 12 valve 5.9 Cummins. Of course since its this far along, new seals everywhere and paint while we are at it
    Wade sitting next to whats left after the tear down, Thats just the transmission and rear end left. otice the poor woodworking tools have been shoved aside.
    PTO has been removed along with the Rock shaft and load sensing for the 3 point hitch. Top left of the photo you see a white thing on the floor, that,s the wheel center. Solid cast and weigh about 500 pounds each
    The new engine tub. The 5.9 won't fit in the Waukesha without extensive modifications. The replacement is from and 1850 Oliver that comes with a Perkins.
    One of the Bearings out of the Tricycle front end steering. I think its junk Its getting new upper and lower bearings and seals
    This is the tower for the steering. The bearing in the previous pic came from the bottom end of this
    The new heart!! 1988 5.9 12 valve Cummins 180HP Cleaned up and ready for paint
    Of course this meant some new tools, like the sandblast cabinet in the background and a new portable air compressor. Yes that was a tool gloat
    New Clutch, pressure plate, PTO drive hub and flywheel where installed. These parts are all new. Since this engine was never offered in this tractor the parts where Supplied by AGCO and come from a White 140. Also had to change the flywheel housing so we had something to bolt the rear mounts to. It came from a Gradall forklift
    Front cover was removed and fixed the Killer dowel pin. It's a lineup pin in the case that can come loose and fall into the timing gears. Not a good thing. Also had to add the side filler neck, Change the fan hub out, the tension bracket is different. Also had to get a shorter dipstick and the lower water neck has to be changed. Those parts where all Cummins. The round cover on the front gets changed out also. The Tach drive hooks up there. More Cummins supplied parts.
    Lower right you can see one of the motor mounts we had to build
    Right front mount. The big hole above it is where the new water neck goes
    Final test fit. Everything lines up and bolted down. Of course it still has to come back out so I can run the new power steering and hydra power lines. Then paint the inside of the tub and the sides of the engine. you can also see the right rear engine mount I had to make.
    Final test fit. The critical part is getting the PTO shaft lined up. If it isn't right bad things happen. Thats the PTO shaft in the middle. It's has splines in 3 places, First its has splines in the back of the flywheel at the PTO hub so it turns all the time, Then it has splines in the middle for the hydraulic pump drive and lastly it has splines in the PTO.
    Throw Apples out the Windows, but make sure not to hit the Penguin.
    If the world should blow itself up, the last audible voice would be that of an expert saying it canít be done.
    13,357
    What a cool project! Looks like you're already making some great progress.
    17,471
    is thatt the old tractor that yu showed me that yu had just got rebuilt and it was trashed already with a spun bearing?? if so must be it died for good huh..i see your stayun busy???)))0
    New Springfield OH
    806
    Larry that was my 1750, pretty much the same exact tractor except for engine, the 1800 was gas the 1750 was diesel. It's still alive.
    Of there is tons of work yet to do Brent and lots of cash to be spent getting it done. Never mind whats all ready been spent on it. It's well up over $4000 so far.
    17,471
    is it gonna be cost effective rob? must be for you to be this committed to it??
    13,357
    I made sure to leave out the 'Why' and 'What are you gonna do with it' questions because I figured they were already way into the 'How' and the 'What does it need' and the 'When's
    Not my place to ask them questions, just good enough for me to watch it come together and be something awesome someday!
    New Springfield OH
    806
    Brent
    Why? Come on, we are guys, and because we can. What other reason would you need?
    Actually its going to get used on the farm. It may make it to a couple tractor pulls
    Larry
    Even figuring in $4500 paid for the tractor 6 years ago, we figure between $10,000 to $12,000. We couldnít buy a field ready 180HP tractor for that. Plus we will know exactly what we have when it's done.
    Feb 2009
    Whittier, CA, USA
    512
    My friends Kerry and Denise run a gasoline powered Oliver 88 for tractor pulls out of Cadiz, Kentucky. Always impresses me when I see it.
    http://www.youtube.com/user/jDeniseU...16/t6qFiJNNi-M
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    Dec 2008
    Santa Claus, In
    4,779
    Dan, I have seen that tractor at pulls
    13,357
    Quote Originally Posted by Robert Mickley View Post
    Brent
    I know! That's why I didn't need to ask 'Why'.
    As in "Why do I have a '46 Chevy out back half restored". Because I'm lucky enough to have a wife who doesn't care, thats why!
    "Why" is not a question that get's asked very often around here...
  1. Need simple project idea for Boy Scout woodworking merit badge project
    By Jerry Ingraham in forum General Woodworking Q&A
    Last Post: 02-04-2012, 07:52 PM
  2. My next milling project UPDATED with pictures
    By John Daugherty in forum General Woodturning Q&A
    Last Post: 10-26-2011, 04:26 AM
  3. new project, lumber is too heavy for me to lift
    Last Post: 04-13-2011, 05:54 PM
  4. Latest "WoodWorking" project - Updated - It Flew!
    Last Post: 01-02-2009, 02:26 AM
  5. Chair Project in progress*** updated partial glue up***
    By Russ Massery in forum Flatwork Project Showcase
    Last Post: 10-16-2008, 10:35 PM
