Results 1 to 10 of 10
Thread: Types of Shop Wood Floors
    Jun 2010
    3,220
    Not long ago Rob K. had a thread on wood shop floors, but I never understood what kinds of wood floors people were referring to. When you say wood floor, are you talking about
    A) a plywood floor maybe over sleepers, that would be like a subfloor in another context? Plywood would be how thick? What quality ply?
    B) planks over plywood? If so, how are they fastened to the plywood?
    C) the good tongue and groove stuff like you would put inside a house?
    D) S4S or rough?
    E) finished? unfinished?
    F) any of the above?
    I ask because the oak floors inside my house (that the previous owners put in) is, of course, finished, and I find it very slippery. It's my first time with wood floors.
    Thanks all,
    AKA The Rookie
    17,475
    Quote Originally Posted by Cynthia White View Post
    D) S4S or rough?
    Thanks all,
    i dont have a wood floor but wished i did.. the term ,,,the good stuff like goes inside a house can be refered to the 3/4"osb or plywood as well. i have seen it finished and unfinshed i also have seen a oak floor that was finished with BLO and it was slick but not real bad..
    12,264
    Hi Cynthia
    Will send you a pdf of the way its done.
    But here is an old picture of my shop floor and what it looked like. Now well its full of dirt black stains all sorts.
    It is 3/4 fir ply butt jointed and screwed down to 2x8 pressure treated lumber 16 inches apart .
    Got some give but not much but is a pleasure to stand on. Best thing i ever did.
    Central NY State
    3,374
    Rob, your floor looks great.
    My floor starts with a slab of concrete, then treated 2x4 sleepers powder nailed and glued to the concrete. 1.5" rigid foam between them. Vapor barrier 6 mil or so. Then 1" thick, 10-12" wide pine that I planed and dried after getting from the sawmill. No T&G anywhere. The pine is face nailed to the 2bys. Finished with BLO 5 coats, then poly 3 coats. It is all beat up, but is great to work on. And my tools thank me every time I drop one on it.
    13,363
    Quote Originally Posted by ken werner View Post
    Any problems with the nails coming up? I bet that looks pretty nice, though, even if it is, as you say, beat up..
    Central NY State
    3,374
    I used some old cut nails I found in the back of a local farm supply store. Not one has pulled up in 5+ years of use. I predrilled the holes. The treated SYP sleepers have probably shrunk since installation, providing a tight grip on those nails.
    Tellico Plains, Tennessee
    4,353
    I don't know what the floors in my shop are made from... they look almost like OSB, but are treated specially for flooring. When they were first installed any liquids spilled on them beaded up and could be just swept out... in the 5 years since the shop was built, they've gotten lots of use, lots of dust, lots of spillage, etc... but are still in pretty good shape. My shop is raised off the ground, about 2 feet at one end, back to less than a foot at the other end where the ground underneath sloped... the guys putting in the shop did a great job and the floors are perfectly level even after 5 1/2 years in all directions.
    Chuck
    Tellico Plains, TN
    PLY or Hardwood
    PLY or Hardwood?
    I can get 3/4" oak for $1 a board foot (typical hardwood flooring).
    It's #3, but thats okay for my shop.
    Should I do that or go with the Ply as many of you have?
    Any recommended finish?
    a sheet of OSB would be 32 bd ft so if it were me I'd go for the oak.
    Inside the Beltway
    2,666
    When Marty did his shop, he did tongue and groove. Looked great!
    Bill
  1. End Grain Wood Floors
    By Vaughn McMillan in forum Carpentry and Construction
    Last Post: 08-02-2015, 02:56 AM
  2. Replies: 12
    Last Post: 02-08-2011, 11:36 PM
  3. Wooden floors in a shop, to be or not to be?
    By Rob Keeble in forum Shop Tours
    Last Post: 02-06-2011, 05:09 AM
  4. Pergo floors
    By Dennis Thompson in forum Carpentry and Construction
    Last Post: 07-21-2007, 12:20 AM
  5. Par-ky (wood tiled) floors
    By Stuart Hanford in forum Carpentry and Construction
    Last Post: 05-27-2007, 12:20 AM
