Results 1 to 6 of 6
Thread: I've been looking & dreaming
    3,134
    About a new shop in the future. 28' x 48' seems a good size with 1 wing as a man cave. With no garage door on either wing. That would make the shop approximately 28' x 36' & the man cave area 12' x 28' & allow for a bathroom too . I would have hinged swinging doors not overhead & make my own stairway raised with a winch. I don't like those fold-able attic stairs.
    http://www.garagebuilding101.com/pla...ar-garage.html
    Well its nice to dream.
    Constantine, MI
    7,891
    Nice, but why not put the man cave upstairs?
    www.wrworkshop.com
    3,134
    Rennie
    It will also be used for a small group meeting of men from the church & I need to remember there could be someone that cannot negotiate the stairs. Also I won't have a regular built in place stairs even if they are regular 8" risers. The stairs will be a one piece structure hinged & raised by a winch.
    Oct 2007
    N. Ga.
    15
    If there's room, a second floor can make a nice bench / hand tool work area.
    I've thought about that for my own dream shop... a spiral staircase in the corner (that takes up minimal floor space) and a trap door in the floor above to hoist things to the second floor. If I recall, there was a shop detailed in Fine Woodworking where that's what the man did. Add a hoist to the ridge beam and you can lift substantial weight, just don't fall thru the trap door when you're upstairs.
    3,134
    The compressor & DC & storage will be upstairs. I really don't want to be running up & down stairs to work on a project. There will be a stairway that retracts into the ceiling & a trap door & hoist or chain fall to raise items to the second story. I also need to think of what my physical capabilities will be in the coming years'
    Thanks for the ideas though.
    Mar 2010
    Decatur, Alabama
    518
    Unless you're really putting some serious machinery in, that's plenty of room. You can fit some good wood storage, finish room, and a nice shop in there.
    Few things I ran into after building mine:
    - Look at your storage room. I only have one wall with nothing interfearing with 12' shelving. I could have relocated the AC and had two.
    - I'd prefer carriage doors instead of roll up too. I put in 8' high roll up doors so the tracks are just over 8' off the floor. It's a huge benefit to me over standard 7' doors.
    - I installed 110V outlets on 6' centers. This didn't end up being enough. I'd go 4' centers or plan on some strips around workbenches with outlets
    - In addition to a 110V dust collector and air compressor, the refridgerator also needs a dedicated 110V breaker.
    - If you have any idea where your DC overhead ducting is going to run, drop the light fixtures down to clear the ducting. I have to lower a couple of mine now because the duct makes shadows across the shop.
  1. I'm (no longer) Dreaming of a White...
    Last Post: 12-24-2012, 04:44 PM
  2. Dreaming of woodworking with pics
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 01-03-2009, 01:35 PM
  3. I'm dreaming of a welded christmas
    Last Post: 12-10-2007, 06:53 PM
