Results 1 to 7 of 7
Thread: Truck bed coating on wood
    Central PA
    638
    I am making some flight cases for my church to store audio cables in. They will mostly live on a cart that will get wheeled around the stage, but at times they will get thrown in a truck and hauled around. I was thinking about using a truck bed coating to paint the boxes. I was looking around online and it seems that most people aren't terribly happy with the DIY bed coatings, but this application isn't as demanding as a truck bed. Any thoughts? I was looking at this
    http://www.rustoleum.com/CBGProduct.asp?pid=368
    30,017
    Hmm...interesting idea. I don't have any idea how well it would hold up, but it seems it should work pretty well. Are you also using aluminum on the edges like the typical flight case?
    I've used vinyl flooring on road* cases with good success. (Black might not be real easy to find, but I was able to get some...this was years ago.) As I recall, it was less expensive that the standard Formica or indoor/outdoor carpet that you see on the commercial cases. I've also simply used black enamel paint, and it also held up remarkably well, even after thousands of miles and hundreds of stage setups. It's easy to touch up, too.
    * I call 'em road cases because we never flew anywhere in the band.
    Central PA
    638
    They won't have aluminum edges or corners like regular cases, these are being made on the cheap. They are made of 3/4 birch ply and I mainly wanted to keep the wood from getting chipped up. They probably won't get much abuse.
    30,017
    Yeah, in that case Formica or sheet vinyl wouldn't work. I'd think the truck bed coating would be just fine, especially with a decent primer between it and the wood.
    I'd suggest using a router with a roundover bit to ease all the exposed edges and corners. Also, I'd suggest putting some type of feet on the cases to keep the bottoms from getting too beat up. Either rubber or metal would work.
    Central PA
    638
    I already put a roundover on the corners. I think its a 1/8" radius but I think I may do a 1/4"
    North West Indiana
    6,099
    I have not done it, but have heard of people using it on their livestock/horse trailer floors and walls and having good luck with no rot due to urine.
    Jon
    5,321
    Take a look at the Duplicolor® brand - the one with the kevlar in it. I used it a couple years ago on a small yard trailer, and it's holding up very well (on metal, at least. I've never tried it on wood).
  1. Getting Big Pieces of Wood into the Truck Question
    Last Post: 11-21-2011, 10:52 PM
  2. Spalting and coating
    By Rob Keeble in forum General Woodturning Q&A
    Last Post: 09-22-2011, 07:22 AM
  3. Clear coating Pine tongue and groove walls
    By Roy Cooper in forum General Woodworking Q&A
    Last Post: 06-07-2011, 12:53 AM
  4. Truck woes
    Last Post: 09-02-2008, 06:09 PM
  5. bad truck, bad!
    Last Post: 12-03-2007, 06:00 PM
