Results 1 to 7 of 7
Thread: Vacuum for Router
    Feb 2011
    Great Pacific Northwest
    71
    Vacuum for Router
    My shop is the garage, so dust and chip control is an issue. I have a shop vac (2 1/2" hose) which works OK on the TS as both saw and vac are stationary.
    I just got a router and am thinking that the 2 1/2" hose is pretty stiff to have to fight with while moving a router around a workpiece.
    Anyone have the smart fix for that problem?
    Tom
    Put the router in a table and move the work piece, much easier than holding the router. Once in the table, hook the vac hose to the router table fence.
    Look around and check out home build router tables, most have a provision for the vac hose.
    Tom...
    Quote Originally Posted by Tom Hoffman View Post
    Tom...
    What he said
    Apr 2008
    Independence MO
    561
    What router? The Bosch 1617 series had a dust port that surrounds the bit. Several have edge guides. Dewalt 621 series has built in dust collection, but all of these solutions, use a smaller shop vac hose (1 1/4 from memory).
    Also consider a clamp with a bungee holding the hose up out of the way. (or some other way of holding the hose overhead)
    I think he may be asking about something more like item #382 or #523 at the bottom part of the pages here.
    Feb 2011
    Northern Lower Michigan/Troll
    196
    I have one on a Safety Speed Cut Dadoing machine running a 3 1/4hp PC router, and I have to say it does not pick up everything, but it is not all that bad. The stuff it misses is the chips that run back down the dado at speed. Not enough air flow through that hole in the lower plate would be my guess.
    Maybe I should try enlarging the lower hole?
    Larry
    Feb 2011
    71
    Thank You
    I think between Glen's link using a smaller diameter hose and the adapter to step up to the shop vac hose (a 382 and a 444), held out of the way using Randals' overhead bungee will do what I was thinking.
    Don and Tom H, Do you guys get all your router work done on a table? I was expecting there to be some types/styles of cuts that would work better freehand.
    Thank you all for advising a newby,
    Tom B
  1. How much vacuum do I need
    By Dave Gallaher in forum General Woodturning Q&A
    Last Post: 09-27-2011, 04:37 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Leigh RVA1 Router Vacuum Attachment
    By Tony Falotico in forum Old Ads
    Last Post: 01-13-2010, 11:30 AM
  4. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  5. Vacuum Rig Ver. 2.0
    Last Post: 03-28-2008, 12:03 PM
