Results 1 to 6 of 6
Thread: pdf files
    Jun 2010
    3,220
    pdf files
    I'm assuming we can upload/attach a pdf to our post, no?
    If so, is there a file size limit on it?
    The reason I ask is that when I scan something in from our scanner, the pdf files are usually GIANT.
    AKA The Rookie
    13,443
    Be sure that the background of your scans are white by laying a piece of paper behind the scanned area. Dark backgrounds can make a typical small pdf about 1000 times larger.
    There is 150 kb limit on the pdf file size.
    Mar 2010
    Decatur, Alabama
    518
    Try scanning it in the lowest resolution also. .pdf doesn't usually make file sizes big, I use adobe standard all the time at work for making instruction manuals. If your pdf's are coming out really big, it's because of the scanned image, not the file type. I don't suppose you can scan to another format that you can edit?
    13,360
    Or, if you don't need it as a pdf, scan it to a jpg file...
    Inside the Beltway
    2,666
    Quote Originally Posted by Cynthia White View Post
    PDFs were invented by satan to torment humankind! Scan the target as a jpg...
    Bill
    The Heart of Dixie
    4,268
    By all means check the PDF program settings. Odds are some of the settings are off. I would check the DPI (dots per inch) settings, probably set to 600 DPI or close.
    I just had the opposite problem. I created a high DPI image for an add and then didn't notice the PDF program was set to 72 DPI and totally messed me up.
    Custom built boats and Kits
  1. Upload files the Easy way
    By Brent Dowell in forum Site Questions and Test Posts
    Last Post: 04-24-2015, 05:30 PM
  2. A Question About Needle Files
    Last Post: 05-18-2014, 04:56 PM
  3. Hand Files?
    By Kris Petrosky in forum General Woodworking Q&A
    Last Post: 03-19-2011, 09:28 PM
  4. Saws and files
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 03-12-2010, 09:33 PM
  5. attaching files
    By roger johnson in forum Site Questions and Test Posts
    Last Post: 11-15-2008, 03:47 PM
