Results 1 to 9 of 9
Thread: When making segmented blanks, how are you measuring the length of your segment edges?
    Mar 2011
    North Central Wisconsin, and Antioch, IL
    16
    I want to try my hand at some segmented rings.
    I've got the Segmented Projet Planer software.
    I draw my vessel, and on one ring, the length of my segment is to be 1-25/32" long.
    20 segment ring.
    First of all, how important that each segment be 1-25/32" long...on the dot?
    If I need to be dead on, within 1/32, how are you guys measuring your segment lengths, before you cut them, to achieve this?
    -Sue
    If you're looking for the lowest price wood on the web, WWW.ThinBoards.com.
    Specializing in wood under 3/4"...but we have some thicker stuff too.
    Sue, I'm not a segmenter, so take this with a grain of salt, but I believe the very good segmented turners like Malcolm Tibbets use digital calipers to measure their segments, and they're shooting for a lot closer tolerances than 1/32". Malcolm uses various jigs for cutting and sanding his pieces, so once a jig is dialed in, he doesn't have to measure each piece. But while getting things set up, the more accurate the cuts are the more accurate the finished work will be. A 1/32 difference between two pieces of wood on a table is no biggie, but a 1/32" difference on a dozen segments in a ring can add up to problems.
    That said, if the error is consistent among all the pieces in a ring, as long as the angle is right you'll still get tight joints. The ring will be a bit smaller or larger than you'd planned, but it'll still be structurally sound.
    Mar 2011
    16
    Yes, I realize this.
    I'm trying to figure out what sort of jig to rig up.
    -Sue
    You might check out Malcolm Tibbetts' book or DVDs. I think he shows some jig ideas in them.
    As I recall, Malcolm uses a sliding compound miter saw to cut his segments to rough length, then uses a jig on a big disk sander to get to the final length. I know some other segmenters use a table saw sled for cutting their segments, but don't recall how they set them up for cutting the exact angles and lengths they need.
    Cotswolds, UK
    629
    Sue, I don't actually measure the segments as such before cutting, just check the jig stop settings on a scrap piece.
    Now Jig is rather a grand word as I use a chop saw to cut my segments.
    (It's essential that the blade and support base are set up square to get a true 90deg.cut)
    I just have a simple adjustable stop fence to locate the first cut edge on for narrow segments.
    For wider segments for lids where I use a lot of small offcuts up I use a simple pencil line on the Left Hand Fence to set the width.
    See attached images.
    I find that by using my calculator with a bit of size padding added to cover dimension and glue up errors that the method is close enough.
    Attached Thumbnails Attached Thumbnails DSCN2436M.JPG   DSCN2437M.JPG   DSCN2433M.JPG   DSCN2434M.JPG   DSCN2435M.JPG
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    Los Angeles, CA
    2,668
    Like Vaughn said, Tibbett's book/DVD is a very good reference for segmented turners.
    For simple segments, a table-saw sled works just fine.
    http://semiww.org/wiki/doku.php/memb...table_saw_sled
    For more precision and particularly for feature/design rings, a disc-sander jig is needed. I think Curt Theobald also uses a jig like that in his DVD
    http://www.curttheobald.com/store.html
    This is how I calculate segments without any software:
    http://familywoodworking.org/forums/...ight=segmented
    Los Angeles, CA
    2,668
    You can see the disc sander jig in this video:
    http://www.youtube.com/watch?v=HO6zQhHvAn4
    Apr 2009
    murrieta ca usa
    45
    Sue I to use a table saw sled nothing fancy just enough to hold segments and a stop block to keep each piece the same size. as far as dimensions you can be off a little but the more segments the dimensions become more critical .
    Nov 2010
    Richmond, MI near Port Huron
    64
    segmenting
    Sue take a look around this site. You can order DVD's and the arrive in a very timely fashion.
    tahoeturner.com
  1. 60 Segment Bowl
    By William Young in forum Lathe Project Showcase
    Last Post: 01-13-2015, 05:53 PM
  2. Mesquite and making pen blanks
    Last Post: 01-06-2013, 03:05 PM
  3. Anyone use a glue other that Titebond for segmented blanks?
    By Sue Nerlau in forum General Woodturning Q&A
    Last Post: 04-02-2011, 05:34 AM
  4. Planing/smoothing edges of hardwood frame on plywood edges?
    By allen levine in forum Neander Woodworking Q&A
    Last Post: 07-03-2010, 01:32 AM
  5. Measuring tape - not only for measuring
    Last Post: 12-06-2007, 08:01 PM
