Results 1 to 4 of 4
Thread: Building up a finish - finishing an open pore wood
    Long Hill Township, NJ
    467
    Help . . . .
    I'm in the finishing stages of a project using some varieties of mahogany.
    I was hoping that shellac would fill the open pores and after enough coats would give me a smooth finish. Doesn't appear to be happening after 6 - 8 coats of Bullseye Shellac.
    The open pores remain open. I'd post pictures but then I'd ruin the surprise on the box swap. I'd rather ruin it when the open the box and see my creation . . .
    Anyway - since I'm 6 - 8 coats in I'm not sure I can use a pore filler - if I could find one. Is this due to the open pores of the wood or am I missing something? Should I thin the shellac so it flows into the pores? Is 6 -8 coats a mere pittance when using shellac?
    I'll try to post a cropped picture in a short while.
    Jim
    You'll probably hear everything you don't want to hear so I'll just start right in. As you discovered shellac will not fill voids well at all. Secondly shellac is a thin film finish, it does not build well and generally demonstrates alligatoring or other unpleasant behavior when too many coats are used. The fact that you have gotten to 8 coats without issue is a credit to your enormous skill; my hat is off to you.
    I continue knowing that if I were at the point you are now, I would convince myself that "the pores are beautiful" and "what was I thinking in trying to fill them up" . If I were dead-set on a pore-free finish, I would strip all the shellac off with rags soaked in DNA, changing rags furiously and scrubbing like I was trying to remove the color of the wood itself. Then use a pore filler to take care of most of the stuff that didn't get filled and 2 coats of shellac . . . and then a bit of paste wax.
    30,002
    Are you sanding back to raw wood after every coat or two of finish? Unless you re-level the surface as you go, the pores will always be the low spots.
    Apr 2009
    Outside the beltway
    5,250
    now you got the shelled on an easy remedy is to use denature alcohol and rub the finish off. using a figure 8 motion remove as much as you can, changing rags often. When you get down to almost bare wood the grain may or may not be filled depending on how you did. After you are dots that point sand and finish. There are other option but there conplexed.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
  1. finishing old and new wood
    By John Daugherty in forum Finishing School
    Last Post: 12-27-2014, 05:39 PM
  2. Reference for Wood Finishing
    Last Post: 12-20-2013, 09:55 PM
  3. first step in finishing the finish room
    Last Post: 11-03-2011, 11:00 AM
  4. Finishing a new wood floor
    By Tom Hoffman in forum Finishing School
    Last Post: 12-30-2010, 10:25 PM
  5. BEHLEN Pore-O-Pac Wood Grain Filler
    By Scott Turner in forum Finishing School
    Last Post: 04-17-2008, 06:16 PM
