Results 1 to 10 of 16
Thread: Router bit burn
    Tampa
    281
    Router bit burn
    I am getting a lot of burn trying to route a panel mould. I am using a CMT panel bit on my router table with a Hitachi variable speed 3hp router mounted on it. I have tried several speeds from slow to the fastest but the burn doesn't seem to go away.
    The bit is almost new, I have only used it a few times.
    How can I get rid of the burn and how can I avoid it.
    Thanks in advance.
    Sharp bit, bit speed and feed rate are a lot of it. Just because the bit was used little doesn't mean it didn't get into something a little abrasive (like wenge for instance). Material control can also have a large effect on burn. Do you have feather boards in use? Its interesting that it only appears to be burning at the outer edge where the speed is slightly greater. I usually get burn in the arch. As to getting rid of what you have; I use a scraper as soon as I can after the cut.
    Tampa
    281
    I am using two feather boards, top and side and I am doing partial bites at a time. I did run some at high speed and fed the peices as fast as I could so I think your comment of feed speed is the key here.
    5,320
    You didn't say what the wood is. Some, like cherry and maple, burn easily.
    Try feeding as fast as you can feel safe with, and also sneaking up on the final cut. I usually take at least three passes to rais a panel - one 'hogging' cut to get rid of most of the waste, then just raise the bit maybe a sixteenth for a 'pre-finish' cut, and finally another thirty-secondth or so for the finish cut. That seems to minimize problems for me.
    I'm about to make ten doors and three drawer fronts myself. I'm using Hickory this time. Never used it before, so this might turn out to be a learning experience. Wish me luck!
    Feb 2011
    Northern Lower Michigan/Troll
    196
    Occasionally I will run into a wood, or have to make a cut with a bit that is marginal at best and a way to get through it is to change bearings. Put a bearing on that is a wee bit bigger, hog off the majority of the wood, put the correct bit back on and take a fast pass.
    If you are using a router table, just adjust the fence out for the rough, and then set it for the final.
    Its a bandaid, but I live where such things as good bits and sharpening are mail order, so I fudge it once in a while.
    Just a thought........
    Larry2
    Oh, guess I should have read the rest of the posts first, but it seems to be a consensious.
    Tampa
    281
    I am routing ash and maple, the maple burns much easier than the ash. I am using two passes but I am going to make it three with the last pass just enough to cut out the burn if any.
    N.E. Arkansas
    374
    Quote Originally Posted by Julio Navarro View Post
    Likely you are feeding too slowly, you should go along at a pretty good clip but not enough to cause the material to split out. I will occasionally, when having a little burn trouble, climb cut the material on the first cut then the final pass the right way. Climb cutting is a good technique but you should not attempt it if you do not understand the physics.
    I once heard that cats and women will do darn well what they please and that men and dogs would do well to accept it and just go on.
    4,552
    Quote Originally Posted by Jim Hager View Post
    Or at the lest a stock feeder
    A Turn N Time
    Frog Pond Guitars
    Floydada, Tx
    1,941
    I have found that using bits with a slight angle on the cutter seems to cut better then the bits with straight cutters. Maple wll get burn marks if the bits are getting dull or fed to slow.
    Jun 2010
    3,220
    Quote Originally Posted by Al killian View Post
    Can you show me an example of a bit with an angle on the cutter?
    AKA The Rookie
  1. Burn in finish
    Last Post: 11-05-2015, 10:24 PM
  2. Never burn a bridge!
    By Chuck Ellis in forum Off Topic Discussion
    Last Post: 04-09-2015, 02:22 AM
  3. ts blade burn
    Last Post: 02-19-2011, 05:22 PM
  4. Getting rid of router bit burn - Scraped clean
    Last Post: 05-11-2010, 08:28 PM
  5. Burn or No Burn?
    By Vaughn McMillan in forum General Woodturning Q&A
    Last Post: 08-17-2007, 03:20 AM
