Results 1 to 10 of 26
Thread: Emergency Box Finishing Advice Needed
    Jun 2010
    3,220
    Talking Emergency Box Finishing Advice Needed
    Yes, okay, I'm running a touch late. My box is ready for finishing. Now this is what I have at home.
    I have dry shellac but not the denatured alcohol (have to drive an hour to pick it up). I also have a better quality bees wax.
    I want this all done by Wed. That's 48 hours.
    What do I have time to use?
    I know I have time for the oil and just the wax. (thanks Vaughn). Do I have time for anything else? I didn't know I could find the Bullseye spray shellac until this morning.
    In what order?
    How long do I wait to wait between steps?
    When do I have to sand (again) and with what grit?
    Thanks for any and all advice!
    AKA The Rookie
    well not knowing the wood type and what look you are going for makes it a little harder but I'd say use the wipe on poly, sanding at 400 to knock down the nibs between coats. Use the sponge sanders if ya go em. Time between coats will vary with temp and humidity.
    May 2009
    Syracuse, Nebraska
    669
    IMHO you won't have time for the oil. I would go with a seal coat of shellac and then either the wipe on poly, 2-3 coats or spray poly, which ever dries faster. I prefer to wait a week before final waxing to be sure the poly is dry. I actually prefer lacquer instead of poly, and Deft has it in spray cans or qt. cans for brushing or spraying.......at least it is here in the Great Plains (or pretty good plains) Good luck
    30,014
    Throw the stain away, IMHO. Beyond that, any of the products you show will work fine. One or two coats should suffice. The more coats you apply, the glossier it will be. If you're looking for a "Grand Piano" gloss, save it for the next project, as there's not time (and you likely don't have the buffing supplies) to do it on this one. (Also keep in mind that wax is not a finish. It's a protective layer for the finish.)
    You're making this way more complicated than it needs to be, Cynthia. During the period of time you and I have been discussing this offline, I've put two coats of a wipe-in varnish/oil finish on my swap box and now it's pretty much done. This is not the time to be experimenting with exotic finishing schedules. Just put some finish on the wood and wait. Like Don said, you can use 400 grit sandpaper between coats to get rid of the dust bumps that may develop, although ideally the last coat shouldn't need sanding.
    13,360
    Just go with the wipe on poly and you'll do fine...
    Apr 2009
    Outside the beltway
    5,253
    Put 3 coats of the shellac on and sand between coats. Give 2 hours drying time between coats and brush it out thin. Then take the Poly you have is the spray can and apply one coat wait the recommended time of drying and apply another coat. Wait the drying time period and sand with a high gt paper 400-600 and either spray on another coat or wax. You can get this done in 2 days.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Sep 2007
    Plainwell, Michigan
    4,857
    Dang rookies just putting on the finish........OH RIGHT I have to do the finishing on mine tonight also (yes I so am a rookie)
    Jun 2010
    3,220
    Quote Originally Posted by Tom Niemi View Post
    Thanks for saying that Tom. Misery loves company.
    And thanks to everyone else! This box swap is interfering with my posting! Gotta run!!
    AKA The Rookie
    Apr 2009
    Outside the beltway
    5,253
    I kind of want to make a BOX too.....................
    But I would need a reminder for the next one and about 3 months in advance
    Apr 2010
    North of Reno, NV...middle of the desert
    1,930
    Cynthia, just put the finishing agent in the box and let the receiver finish it up as they see fit. I love it how all of you are stressing over this
  1. Easy Beginner Finishing Advice Needed
    By Cynthia White in forum Finishing School
    Last Post: 11-11-2010, 05:44 PM
  2. Advice needed
    Last Post: 10-19-2010, 05:07 PM
  3. OK, now what! (Veenering/finishing advice please)
    By Jeff Bergman in forum General Woodworking Q&A
    Last Post: 02-10-2010, 07:27 PM
  4. Advice needed
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 07-10-2009, 03:37 PM
  5. Advice needed
    Last Post: 09-14-2008, 04:33 PM
