Results 1 to 10 of 13
Thread: Now I know why I need
    San Antonio, Texas
    765
    Angry Now I know why I need
    to make me a bowl steady. I was making the final pass (very light finishing cut) on the inside of a bowl of spalted Maple crotch. All was going well. The bowl was singing to me (wall thickness was about 3/16"), but I wasn't alarmed. Then when the bowl gouge (Ellswworth grind) was about 5/16" from the rim... POW! Blew a 2" x 4" chunk out at the rim. I wasn't removing that much material (1/32" maybe), and I was taking it easy. All I had left to do was sand and finish. Needless to say, I was really... (expletive deleted)! LOML had already claimed it so I brought it in to show her. She was nearly as upset as I, but then said, "Okay, just turn it into a high rimmed platter and I'll use it for candles."
    Now if you'll excuse me, I have to go hit the thrift stores for a used pair of roller blades.
    15,815
    BTDT feel you pain dude!!
    30,233
    Quote Originally Posted by Billy Burt View Post
    ...Now if you'll excuse me, I have to go hit the thrift stores for a used pair of roller blades.
    Sorry to hear of the bowl explosion. Those suck. I had good luck finding wheels and bearings on eBay. When I have a bit more time, I'll post pics of the steady I finished up last weekend.
    New Springfield OH
    806
    I suggest you keep her, of course you explained that with a bowl steady this may well not have happened?
    North Ogden, Utah
    348
    That's too bad. Sounds like it was going to be a nice bowl. I've never used a bowl steady but I'm sure I'll have something like that happen someday to convince me to make one too.
    30,233
    As promised, here are a few pics of my steady.
    Goodland, Kansas
    4,834
    Sorry to hear about the explosion. If you check the link that Vaughn give you will see my bowl steady for my big and little lathe. Very similar to Vaughn's.
    Bernie W.
    3,147
    So what actually happens? Does the bowl start to flex & when the tool is introduced even for a shallow cut very carefully done catches on the section that flexed outward toward the tool & bang explodes?
    San Antonio, TX
    57
    I made 2...one is bowl steady and the other is for spindles and vase.
    Bart, when you make a cut, you are always putting some pressure on the wood..no matter how light you make it and how sharp your tool is. On a thin bowl (more for platter) this is critical. Signs of impending trouble (for me) is the resonating sound. The steady helps releave/counter that pressure and minimize any flex.
    Dario
    http://www.aoturnings.com/
    Westphalia, Michigan
    955
    I always switch to a sharp scraper when I get that thin. I havn't had a serious catch since.
