Results 1 to 9 of 9
Thread: bosch contractor job saw
    17,471
    tod has one at the job site and his customer just called and said it wont start back up..is there a reset button on there anwheretht needs to reset? its a model 4000? but it needs to get back on for monday
    thanks for any help that can help us out...
    NH
    4,005
    Tell his customer to plug it in.
    Oh and to stay away from Tod's tools
    Stupid hurts.
    17,471
    tod told me what to say to you but the rules prohibit it here
    13,439
    Looked up the manual, doesn't say anything about a reset. I'd be with Chuck, check the cord and the breaker.
    From the manual:
    TROUBLE: SAW WILL NOT START
    PROBLEM
    1. Power cord is not plugged in.
    2. Fuse or circuit breaker tripped.
    3. Cord damaged.
    4. Burned out switch.
    REMEDY
    1. Plug saw in.
    2. Replace fuse or reset tripped circuit breaker.
    3. Have cord replaced by an Authorized Bosch Service
    Center or Service Station.
    4. Have switch replaced by an Authorized Bosch Service
    Jan 2011
    Tacoma, WA
    274
    There is a backup system in the gear box. You need to check to see if the pug fell out and the hamster got lose. I think it's like $12 for a new hamster and a piece of duct tape to cover the hole and your good to Go!
    I've got the same saw. Don't know what would cause it to just stop working.
    I would check to make sure you have power at the saw, then I would do a continuity check of the saw to make sure power can go through the saw and to make sure the switch is working. I would also make sure a cutoff piece of wood is not stuck under the blade in the dust shroud.
    Last I would check the brushes on the motor to see if there is something wrong here, though the continuity test should give a ruling on this too.
    Sorry, that's all my 2cents can come up with.
    On this plus side, this could be a great opportunity to buy a new sawstop contractor saw!!!
    Brian
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    13,360
    Maybe a mouse chewed through the wires... It's happened on a couple of our vehicles...
    17,471
    thanks for the help guys, will pass this on to tod
    Jan 2011
    3,798
    I'm put'n my money on the circuit breaker, we trip them 15 amp'rs all the time with circular saws...on more than one occasion, had to give a homeowner a clue as to what those little numbers meant on the breaker... I'm all in
    11,828
    "customer called"?
    I'll bet it is the automatic idiot control safety switch that activated.
  1. sawstop contractor saw
    By Chris Mire in forum New Tools
    Last Post: 07-06-2009, 09:13 AM
  2. used Delta contractor saw
    By Al killian in forum New Tools
    Last Post: 06-16-2008, 05:00 PM
  3. New Jet contractor saw JWTS-10
    By Chuck Hanger in forum Old Ads
    Last Post: 04-17-2008, 07:00 PM
  4. Contractor Saw Tune Up
    By Mike Gabbay in forum General Woodworking Q&A
    Last Post: 02-16-2008, 08:14 PM
  5. Bosch Colt and Bosch Jigsaw
    By Jim C Bradley in forum New Tools
    Last Post: 10-30-2007, 05:18 AM
