Results 1 to 10 of 21
Thread: Doing the Wave
    30,008
    Doing the Wave
    Since there were a few people who asked about the wavy lines on the sides of the box I made for the 2011 swap, I figured I'd share how I did it...
    Cut a wavy line in a 3/4" cherry board. I used a bandsaw and oscillating spindle sander to clean up the cuts and get the two pieces to fit with no gaps.
    Soak some 1/16" thick x 3/4" strips of contrasting wood in hot water for a couple hours to soften them.
    Clamp the soaked wood tightly - with no glue on any surfaces -between the two halves of the board. Let that sit a day or two until the wood's dry. This gets the curves started in the accent strips, although there will be some springback when it comes out of the clamps. It'll look something like this when you take it out of the clamps. (BTW, these pics are from a box I made a few years ago):
Name:	Cherry Wave Construction 1 800.jpg
    Next, glue it all up (I like using plastic resin glue like DAP Weldwood) and let it dry in the clamps for a day or so. After that, I plane the board flat again, then resaw it into two bookmatched boards that end up about 1/4" or so thick after planing.
Name:	Cherry Wave Construction 2 800.jpg
    From that point on, it's just a matter of building a simple mitered box. With some care and planning on the miter cuts, you can get the accent line to line up from one side to another. The miters have to be cut so that no wood is removed from the outside face of the board. If not, the lines won't be aligned.
Name:	Wave Box Miters 800.jpg
    On this box, I got two of the four corners lined up. The other two are off a little bit. When there's no gap, the corners will look like this:
Name:	Cherry Wave Box 3 - 1 800.jpg
ID:	55537 Click image for larger version.
Name:	Cherry Wave Box 3 - 2 800.jpg
    And here's what happens when there's a gap in cutting the miter...in this case the gap was about the width of the saw kerf (3/32").
Name:	Cherry Wave Box 3 - 3 800.jpg
ID:	55539 Click image for larger version.
Name:	Cherry Wave Box 3 - 4 800.jpg
    There ya go...
    Dec 2008
    Portland, Oregon
    1,898
    Thanks Vaughn That's a great tutorial!
    Now how did you chuck up the rectangular lid to cut the swooshes in it??
    I'm not much of a lathe guy
    Jesus was a Woodworker
    Inside the Beltway
    2,666
    OK. But how, exactly, do you do that? Cut most of the way, at an angle, and then use a knife? Tilt the table on a bandsaw? I'm completely missing something here...
    Bill
    NH
    4,005
    Quote Originally Posted by Dan Mooney View Post
    I'm guessing the handle on the lid is placed in just the right spot to cover up the hole from the bottle stopper mandrel or the screw that went through into a waster block.
    Stupid hurts.
    30,008
    I cut it on the tablesaw, but set the blade height to just clear the thickness of the board. I was feeling pretty lucky to have gotten two of the four just right.
    No screws or waste blocks. I used a vacuum chuck in three different positions. First, the piece was centered, and the curved profile of the top was turned and sanded. I used the tailstock to center the piece and hold it while making the initial profiling cuts. Then I mounted the piece offset (with no tailstock support) to make the crescent cuts on one side, then mounted it offset the other direction to do the other crescent cuts. The one crescent that's deeper than the other two was done that way to hide the scars from the catch I had that blew the lid off the lathe.
    The knob in the middle is only hiding the dimple made with the live center in the tailstock when I did the initial profiling of the lid.
    NH
    4,005
    Your one crafty guy Vaughn
    Stupid hurts.
    3,132
    Good tut ya got there. i might have to give that a try one of these days.
    Aug 2008
    Reno, Nv
    3,632
    Sweet job El' Jefe...lotta cool tricks!
    10,600
    Great tutorial Vaughn
    13,357
    Sweet! I've used that resawing technique to make the grain wrap all the way around a box before, but never thought about doing a wavy strip...
    Sweet!!!
  1. Wave Cabinet
    By Dan Mooney in forum Flatwork Project Showcase
    Last Post: 12-31-2015, 08:42 PM
  2. Wave Cabinet
    Last Post: 07-01-2015, 12:34 PM
  3. Quake and wave warning
    By Jim Burr in forum Off Topic Discussion
    Last Post: 07-06-2011, 07:57 PM
  4. Doin' the wave!
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 04-02-2011, 01:45 AM
  5. Can I post a wave file?
    By scott spencer in forum Site Questions and Test Posts
    Last Post: 09-07-2010, 04:29 AM
