Results 1 to 10 of 13
Thread: Home-Built Lathe Steady
    30,136
    I mentioned this in another thread, so I thought I'd show a few pics of a lathe steady I built recently. It's made primarily of 1/2" BB ply, except the base, which is jarrah. The "ring" is two layers of 1/2 ply glued and pinned together, and the "arms" are a single layer. I painted the ring bexause I originally cut the slots for the two lower arms at the wrong angle, and had to fill the slots and re-cut them correctly. I also filled any countersunk screw holes. The paint hides the patches.
    The base is made of some leftover jarrah I had. I figure if it's good enough for piers and heavy piling, it'll hold up for my needs. To mount the ring on the base, I cut long slots in the bottom of the ring with the mortiser, then glued and screwed the base into the slot from above and below. It's not going anywhere. I originally thought the plywood arms would be too flexible, but so far they've proven to be plenty stiff. The ring is also very rigid.
    The wheels, bearings and axles were purchased on eBay. I read somewhere recommending the use of softer wheels (78a to 80a, with lower numbers being softer). These are 78a wheels and they do have a little "give" to them, which I believe is a good thing.
    The upper left-hand arm and wheel do block the beam of the laser (but not the bar holding the laser), so I think I'll cut another slot at the 9 o'clock position for that arm and move it there when I'm getting down to the last bit of finishing the inside.
    Here are a few pics and a sketch:
    Front side:
Name:	Bowl Steady 1a 800.jpg
    Back side:
Name:	Bowl Steady 1b 800.jpg
    Base:
Name:	Bowl Steady 1c 800.jpg
    And a sketch showing more clearly how the base is inserted into a slot in the ring, although I didn't bother rounding the corners of the ring as shown in the sketch:
Name:	Bowl Steady Sketch 800.jpg
    So far, with a single use, the steady seems to be doing what it's supposed to be doing. Now if I could only get the lathe back in business. (Parts have been ordered.)
    15,811
    Very nice job, I need to make a better one, or get some better wheels, the ones I have "wobble" which don't work well with keeping things "Steady"
    How much did you pay for four wheels?
    30,136
    ...How much did you pay for four wheels?
    I got 16 wheels and bearings, with 8 axles, for $26.50 shipped. I'm planning to hang onto the remaining four axles and four of the wheels for potential future projects, but I'm considering selling the rest of the wheels and bearings.
    I know a lot of guys have had good luck buying used rollerblades at thrift stores, but I dunno if Tokyo has much of that sort of thing. These run real smoothly, although I did use some CA glue to hold the wheel hub onto the bearing a bit better. It's a friction fit, and with a bit of sideways pressure on the wheels, they would get unseated and start to wobble. The CA sees to have fixed the problem, but I can still pop them out if need be with a well-placed tap from a hammer. I'll have a better feel for how it works after a few more miles of test driving.
    North Ogden, Utah
    348
    That's a good looking set up Vaughn. Someday (I have a lot of somedays to catch up on) I'm going to build one.
    11,874
    Good looking set up, and apparently very effective. Wouldn't work on my Grizzly. The motor is mounted 'backwards' and doesn't allow anything larger than the 14" swing to be near the spindle.
    Goodland, Kansas
    4,834
    Hey Vaughn great minds must think alike. I built one just like yours. I really like the way it works so I built a small one for the Rikon. I went to Target and bought 2 pair of skates cheaper than I could get them off ebay. Here are my pictures and all from scrap wood. The first 2 are the big one and the second 2 are the little one.
    Vaughn how does that work with the laser? Does it interfer? Thanks.
    Attached Thumbnails Attached Thumbnails Big Steady Rest 1.jpg   Big Steady Rest 2.jpg   Steady Rest 2.jpg   Steady Rest 3.jpg
    Bernie W.
    The Woodlands, Texas
    83
    I Want One!
    Hello Vaughn and Bernie,
    Both of your steady rests look great! I need to build one, or two, or three. When you get a chance to use it, let us know if you have any problems with it marking the bearing spot. I know you can protect the area somewhat with tape, but I'm curious if any compression marks will show up, especially on soft hardwoods. Bernie, you may be able to answer this now??? Take care and all the best to you and yours!
    Better Woodturning and Finishing Through Chemistry...
    Steve Russell
    Eurowood Werks Studio
    Professional Studio Woodturner
    Steve Clardy Guest
    Good looking SR there Vaughn and Bernie
    30,136
    Good-looking steady, Bernie. I like the t-track for the arms...great idea, especially when Rockler has their t-track on sale (like now).
    Steve R, my experience is still very limited with these things, but from what I've been told, the main reason for buying the softer wheels (78a to 80a) is to avoid making compression marks on the piece. Soft is a relative term here, but the 78a rubber is about as resilient as a superball. (Remember those?) Firm, but it definitely has some 'give'.
    Goodland, Kansas
    4,834
    Quote Originally Posted by Steve Russell View Post
    Steve it does leave a mark but nothing that can't be taken care of with a little sand paper. I haven't had any problem on that regard.
    Bernie W.
  1. Delta 36" lathe with duplicator and steady rest
    By Rich Soby in forum Classified Ads
    Last Post: 05-20-2016, 08:58 AM
  2. Something on Edges of Plywood Lathe Bolw Steady
    Last Post: 03-05-2013, 09:44 AM
  3. Home built dog house I purchased:)
    By Erin Reichelt in forum Flatwork Project Showcase
    Last Post: 10-11-2009, 10:50 PM
  4. Steady Rest for lathe ?
    Last Post: 01-14-2009, 01:48 PM
  5. Lathe Steady
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 12-16-2006, 07:58 AM
