Results 1 to 10 of 21
Thread: Miter Saw Blade Question
    Jun 2010
    3,220
    Okay, I was cruising along this morning trying to get some more shelves up in the shop with some angled supports, and while I was cutting one support, the blade in the SCMS got stuck in the wood. So I shut off the saw, unplugged it, and I had a hard time getting the wood off the blade.
    So now, of course, the blade is no longer square to the fence or square to the table. My question is, is there an easy way to tell if the blade is bent altogether? (before I spend an hour doing all kinds of adjustments?)
    I probably have about 100 hours on this saw (and this blade). This is my SCMS. Click image for larger version.
    No sense showing you a half cut piece of 2X4.
    AKA The Rookie
    11,825
    Sounds like a scary incident.
    Glad no injuries were involved.
    I would suggest just laying the blade on a flat surface, like the table saw top. Lay on both sides if it looks bent, it is bent, if it wobbles it is bent.
    Were you pulling or pushing? A slider CMS is meant to be brought to the front, lowered into the wood then pushed back.
    When I first started with mine, I lowered and pulled but the blade wanted to 'race' through the wood. Then I learned here (it really is a very useful forum) that was dangerous and a backwards procedure.
    Good luck. Let us know if the blade is damaged.
    Jun 2010
    3,220
    Hey, Frank. Yeah, it wasn't so much scary as annoying. I'm not so scared of my power tools anymore. I was all suited up for safety like an astronaut. I stand well away from the saw and to the side. I always use a vise to hold down the board. I fully extend it back, then down then forward.
    So now I have one support fully cut and 10 supports needing 2 more cuts. At least it's sunny today, so I'm going to go outside for a bit.
    AKA The Rookie
    Quote Originally Posted by Cynthia White View Post
    Thats what Frank was refering to thats backwards.
    "Thereís a lot of work being done today that doesnít have any soul in it. The technique may be the utmost perfection, yet it is lifeless. It doesnít have a soul. I hope my furniture has a soul to it." - Sam Maloof
    13,357
    Cynthia, from your description, I believe you are doing the opposite of what Frank is suggesting.
    Were your pulling the slider through the cut or pushing it through? If you are pulling, the blade may want to run towards you across the board. If you are pushing, your are controlling the cut.
    I don't have a slider so I guess I'm confused as to how the saw got stuck in the wood?
    Jun 2010
    3,220
    Okay, maybe I expressed it wrong. I extend it toward me, then down then away from me through the wood.
    AKA The Rookie
    Jun 2010
    3,220
    No, Brent, I'm doing it right, just worded it wrong. I push the saw through the wood. And I have no idea how it got stuck either. But what makes a blade get stuck? A twisted board that binds the blade?
    AKA The Rookie
    NH
    4,003
    Unplug the saw put your square on the table up to the blade. rotate the blade by hand. If the blade moves away from the square than back to it again it has been bent. (guessing not) My guess is the force of the bind knocked the fence out of adjustment. Might even have bent the fence. Like I did on my big Hitachi
    Stupid hurts.
    13,357
    From my mistakes, it's usually something that causes the wood to pinch the blade. Usually it's happened to me on rip cuts where the wood closes up due to stress in the wood.
    But I've never had it happen with a 2x4 on my miter saw. I'm confused.
    Maybe one of the more experienced guys would know.
    NH
    4,003
    Yes.........
    Stupid hurts.
  1. Use the correct blade on your compound miter saw!
    By andy fineran in forum Safety Tips
    Last Post: 12-28-2015, 12:46 AM
  2. saw blade question..
    Last Post: 02-11-2014, 02:11 AM
  3. Bandsaw Blade Question
    Last Post: 12-10-2013, 07:08 PM
  4. Segmented Miter Question
    Last Post: 01-25-2009, 01:26 AM
  5. Bandsaw Blade Question
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 08-04-2007, 01:11 PM
