Results 1 to 10 of 22
Thread: Hollowing rig questions
    May 2009
    Lafayette, Indiana
    2,380
    I have finally started to weld up a hollowing rig system. Today I welded up a "D-Arm" from 3/4" stainless steel shaft. I also welded up a back support rest....which brings me to my first question. I'm building a rig like this https://www.lylejamieson.com/tools/tool_howto.asp . It calls for a backrest of anywhere from 30-38" across. One place one his website he says 30-32" and another he says 38"...My question is....do I really need it that wide? In the case of 38" he states that it should have 10" in front of lathe and 28" in the rear.
    I know some of you have made your back rests so that you can slide them forward and back and I may make mine that way too...just looking at my options. I'll get some photos of it all in the next couple of days.
    I also will then be trying to figure out how to make the cutting tips. My boring bars will be 3/4" bar as well but I need to know how to attach the cutting tools to the tip of the bars.
    30,017
    Tom, I'd recommend making the back rest as wide as possible. You'll be glad to have the extra movement capability.
    For mounting the tips, search the forum for a thread I started a couple years ago about making boring bars. I think the thread title is something like 'A boring day in the shop'. (I'd search for you, but I'm on my phone, so pasting links is a pain.)
    May 2009
    Lafayette, Indiana
    2,380
    Thanks Vaughn, I'll look it up.
    Goodland, Kansas
    4,834
    I agree with Vaughn and would go around 36". You will be glad for the extra movement in the unit. Mine is around 34 1/2" and sometimes I wish I had a couple more inches.
    Bernie W.
    May 2009
    Lafayette, Indiana
    2,380
    Quote Originally Posted by Bernie Weishapl View Post
    I welded up my back rest at 32" however I still need to mount it to the base so maybe I'll come up with a way to slide it on the base forward and backward a few inches to give me that extra length. My lathe sits up against a wall and even at 32" I would still need to pull it away from the wall to use it. I thought I was just saving myself from having to pull it from the wall but I guess I just will have to do that when needed.
    30,017
    Quote Originally Posted by Tom Baugues View Post
    I found it, Tom...
    http://familywoodworking.org/forums/...ad.php?t=13507
    Note that in post #29 I make a correction on the size of the tool bits. They were 3/6" bits, not 1/4".
    Goodland, Kansas
    4,834
    I hear your pain Tom. I had to move mine away from the wall a few inches.
    Bernie W.
    May 2009
    Lafayette, Indiana
    2,380
    I found it, Tom...
    Thanks Vaughn, that helps alot. I have quite a bit of stainless steel shaft here now of several different sizes to make tools with. I saved several old shafts from some machine repair work that I do. I should have enough for a dozen or so tools if needed. I'll now have to be on the look out for square HSS bits.
    30,017
    ...I'll now have to be on the look out for square HSS bits.
    Look no further...
    http://www.use-enco.com/CGI/INSRAR?PMSECT=0000000747
    Pick a size and material. In my experience, the HSS ones work just as well as the cobalt ones. (As I understand it, metalworking benefits from using the cobalt bits because they withstand high temps better. Cutting wood doesn't get the bits hot enough to make a difference.) I've bought the 2" or 3" long ones and cut them (snapped, actually) into two shorter bits.
    3,134
    I found it, Tom...
    I am supposing you meant 3/16?
    And what is meant by back rest is it the part the back of the tool steel holder slides through that captures it & keeps it from twisting or turning?
  1. Hollowing questions
    By Guy Bratt in forum General Woodturning Q&A
    Last Post: 01-02-2011, 04:01 PM
  2. Hollowing Questions ???
    Last Post: 01-18-2010, 05:10 AM
  3. Hollowing Day and Questions
    Last Post: 12-25-2009, 03:33 AM
  4. Hollowing Second Attempt - Questions
    Last Post: 10-07-2009, 02:33 PM
  5. Hollowing First attmept and questions
    Last Post: 10-05-2009, 03:47 AM
