Results 1 to 10 of 20
Thread: cutting 45 angle on a left tilting TS
    Tampa
    281
    I have a Hitachi (strongly regret it) TS whose blade tilts to the left.
    I have a 4" wide board about 24" long that I need to put a 45 bevel on one edge.
    How do I rip the 45 angle, with the wood on the right side of the blade (cutting from underneath) or the left side (cutting from top)?
    Thanks guys.
    I also have a left tilt saw, and I'd make that cut with the fence on the right aide of the blade. I always want the blade tilting away from the fence.
    5,322
    With a left tilting saw, I always cut bevels with the workpiece (and fence) to the right of the blade. That way, you'll never have an offcut trapped between blade and fence (invitation to a kickback).
    Tampa
    281
    You guys are fast!
    The kick back issue also crossed my mind with the wood trapped under the blade.
    Thanks guys, I will do that.
    17,474
    one other suggestion julio is to use a router table to make that cut..
    11,833
    Don't stand in the line of fire. Not fun if it kicks back. DAMHIK
    NH
    4,006
    +1 for what they said
    Stupid hurts.
    Tampa
    281
    You know, Larry, that may be the way to go.
    Floydada, Tx
    1,941
    Router table is going to be the safesy way to go.
    Tampa
    281
    Turns out I don't have a 45 bit, can you believe that!
    I managed to cut it on the TS by raising the blade little by little rather than with one cut. It worked out ok.
    I also used the joiner by adjusting the fence.It took a while but it was a nice cut.
  1. My left eye
    Last Post: 03-01-2014, 02:08 PM
  2. Tilting Spindle on a shaper or not?
    By Brian Altop in forum New Tools
    Last Post: 01-13-2011, 02:46 AM
  3. You Have Only 1 Day Left
    By Vaughn McMillan in forum General Woodworking Q&A
    Last Post: 12-21-2010, 02:54 AM
  4. Only 1 Day Left
    Last Post: 12-21-2010, 02:48 AM
  5. Cutting box cover on angle?
    By John Lasher in forum General Woodworking Q&A
    Last Post: 03-20-2007, 09:33 PM
