Results 1 to 10 of 29
Thread: Spray water based polyurethane finish?
    North West Indiana
    6,098
    Tongue and groove pine, 1450 square feet needs finished. Can I spray water based polyurethane using a spray gun and be successful and have a nice semi gloss finish? This will be for a ceiling. Will have to finish both sides so double the square feet. What would be the best procedure?
    Jon
    30,017
    Not sure what waterbased poly you're considering, but I've sprayed both Minwax PolyCrylic and Target Coatings Ultima Spray Lacquer (USL) with good results. (Target has replaced USL with a similar acrylic lacquer called EM6000.) I've used both a turbine-powered HVLP gun as well as a compressor-powered HVLP gun, and both worked well.
    I have spray H2O based Poly with my HF HVLP gun with no probs.
    NH
    4,005
    Do ya mean like this? http://familywoodworking.org/forums/...ad.php?t=19941
    Nope can't be done, no way. no how.
    Stupid hurts.
    Jan 2011
    Tacoma, WA
    274
    if you have 2900 sqf to do, and it is pine, I recommend wiping it on with cotton balls, that way you can make sure it gets into all the wood poors and if there are any rough spots, the cotton ball will snag and let you know you need to touch it up real quick.
    Ok, maybe not.
    I've sprayed it with a hvlp gun no troubles(long time ago). The water based seems to dry quicker so maybe want to take that into account. Also if your going to do a second coat, some water based poly's require an abrasion first? Don't remember.
    Don't forget to get a good coat on your beard too. I just wouldn't be a good job if you didn't get a good coat of overspray on all your facial hair!
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    NH
    4,005
    Quote Originally Posted by Brian Altop View Post
    A very wise man on both accounts
    All though I find that a Q-tip works better for applying.
    Q-tip = Cotton ball on a stick.
    Stupid hurts.
    30,017
    ...I recommend wiping it on with cotton balls...
    I prefer the texture I get from using wads of dog hair. Of course cat hair leaves a finer finish, but I can get my dog hair for free at home.
    North West Indiana
    6,098
    My my, woodworking comedians. What should we call it, BlueWood Comedy Tour????
    Thanks for the information. Not to give out privileged information, Chuck and I have pm'd and through his efforts, thinks rolling still might be faster.
    I seriously detest cleaning spray guns.
    Yep, planned on using the sponge sanders between coats and before hand. Went back through and first thought, COOL, a great way to get a new sander, then saw Chuck did not have luck using his.
    I could see why, the face of the boards I will be finishing will have the V groove and be tongue and groove. Which begs the next question, spraying the finish, does this affect the tongue and groove from fitting nicely?
    It will be a couple of months before I attack this job, it is for my parent's new house on our farm. All of the comments were/are appreciated.
    Oh, ya'll ain't got nothin on me, I's gots plenty of horsehair for the final application/applicator!
    Jon
    17,472
    with the depression yu have jonathan on the wood i think spraying maybe get in there better ,, but chuck has just got threw a bunch of it so he should be more aware of the time frame.. and cleaning guns isnt that bad jonathan, exspecailly if you look at cleaning brushes after wards too..
    North West Indiana
    6,098
    Nope, buy cheapie brushes I don't mind throwing in the stove. Yeah, the backs, I can see rolling and it really doesn't matter, just want a seal.
    Jon
  1. Can I use oil-based finish over water based stain?
    By Roger Tulk in forum Finishing School
    Last Post: 09-01-2012, 04:24 PM
  2. Oil based stain and water based poly?
    By John Hemenway in forum Finishing School
    Last Post: 02-14-2012, 03:36 AM
  3. Enduro water based finish
    By Rob Keeble in forum Finishing School
    Last Post: 07-23-2011, 05:27 PM
  4. oil based poly over Water based?
    By Dan Thibert in forum General Woodworking Q&A
    Last Post: 05-26-2009, 01:07 PM
  5. Water based retarder?
    By Al killian in forum Finishing School
    Last Post: 12-23-2008, 01:30 AM
