Results 1 to 10 of 10
Thread: Harring Bone flooring
    Floydada, Tx
    1,941
    Question Harring Bone flooring
    For those of you that have used/worked with it, what angle is it cut at? I want to try making some, just not sure what angle to cut it at.
    Jan 2011
    Tacoma, WA
    274
    It is all cut at 90, just turned so the pattern is at 45 with the room. All ends are 90 cuts though staggered on each other. The length of the individual slats must be a multiple of their width or the pattern won't work.
    Brian
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    Jun 2010
    3,220
    Hang on a second Brian.
    Al, there are 2 commonly used patterns for "Herringbone".
    This is the first one that Brian describes. It's the most traditional. All boards are 45 deg from your straight line reference (a wall), and each piece you put down is 90 deg from it's neighbor and parallel to the one behind it or in front of it.
    There's a 2nd less traditional pattern also called a herringbone, or French herringbone, and sometimes called a chevron, that looks like this. Every board is also 45 deg from your straight line reference (wall), but with this one, each piece has 2 X 45 deg cuts on it.
    AKA The Rookie
    Jan 2011
    Tacoma, WA
    274
    Yep, forgot about that one, thanks!
    Floydada, Tx
    1,941
    Thanks, so then thy are just cut into shorter peices. My one cleint was asking me about them.
    Jun 2010
    3,220
    Quote Originally Posted by Al killian View Post
    yeah, that second one would/could use shorter pieces and you'd probably have more waste and more labor....but it is spectacular looking.....
    AKA The Rookie
    NH
    4,006
    Quote Originally Posted by Cynthia White View Post
    Hang on Cynthia
    The boards can run straight with the wall changing in the corners.
    Stupid hurts.
    Jun 2010
    3,220
    Hang on Cynthia
    Not in my house! I'm sure you're right, Chuck....but I can't say I've ever seen it done that way....but yes, you're right.
    AKA The Rookie
    NH
    4,006
    Around here ok in my small world both of what you posted are chevron. One with Herringbone joints and one with out.
    We used to run 4 or 5 strips of flooring all the way around the room as a border Herringboning the corners. Than lay the field butting into the border. One that comes to mind is one that we did the border with a row of cherry a row maple a row of cherry a row of maple than the field in cherry. Now while that may not look good in your house it was stunning in that one
    There was one nook about 4 feet wide by 6 feet long that we ran the pattern right into the middle. It looked like one of those fine oriental rugs when I was done
    Stupid hurts.
    Jun 2010
    3,220
    Chuck, if you were doing the work, I'm sure it would have looked splendid in my house too.
    AKA The Rookie
  1. Bone In New York Roast
    Last Post: 12-24-2011, 01:32 AM
  2. Red oak flooring
    By Al killian in forum Old Ads
    Last Post: 01-15-2011, 09:19 PM
  3. Bone To Pick with Earlex...
    By Art Mulder in forum Finishing School
    Last Post: 08-02-2010, 12:21 PM
  4. Bone Chair
    Last Post: 06-02-2010, 06:14 PM
  5. Whale Bone
    Last Post: 05-20-2009, 10:10 PM
Tags for this Thread
