Results 1 to 4 of 4
Thread: 5/8 inch arbor question
    I have a craftsmen 12 inch compound miter saw which has a 5/8 inch arbor. Most of the 12 inch blades that I have seen have a 1 inch arbor. Does anyone know if and where I can find anything that would fit into the 1 inch arbor blade to make it fit safely on a 5/8 inch arbor saw. Thanks Bob Giustina
    873
    Hi again Bob; see my answer on the CHW forum!
    11,899
    Mack, it would be helpful if you could post it here. I don't know what a CHW is.
    BTW, I had a similar problem and found a packet of various sized nylon arbor adapters at my local True Value hardware store. About six different sizes and it cost all of about $1.00.
    873
    I'm sorry Frank; Bob had asked this same question on a Cdn. site. CHW is an acronym for that site <canadianhomeworkshop.com> I was really just attempting to answer his question, not thinking that some one else might be interested in the answer as well. Sorry about that!
    Hi Bob; You can get an insert for the 1" blade that is 5/8" in dia. Whoever sold you the 12" blade should carry the 5/8" insert.
  1. Replies: 3
    Last Post: 02-20-2012, 02:16 AM
  2. Rockwell Delta 24 inch Scroll saw question
    By Rob Keeble in forum Old Iron
    Last Post: 01-05-2012, 01:39 AM
  3. 3/4 inch vs 1 and 1/8th inch thickness question
    Last Post: 02-12-2010, 12:53 AM
  4. Replies: 1
    Last Post: 11-21-2009, 01:48 PM
  5. 6 inch sander question
    Last Post: 05-04-2007, 01:35 AM
