Results 1 to 10 of 20
Thread: Tung Oil Opinions--New Info
    Jun 2010
    3,220
    For my own education, I'd like to hear from anyone who has an opinion on Tung Oil:
    Do you like it? Not like it?
    Why?
    Do you use it? Not use it?
    Do you use the pure? The "Tung Oil finishes" (which may or may not even have any Tung Oil in them)?
    What do you think about it?
    What do you know about it?
    What do you think you know about it?
    Thanks for any and all replies.
    AKA The Rookie
    Jul 2007
    DSM, IA
    5,719
    I used to use Formby's tounge oil finish on bowls. It worked great, but it is quite a bit more expensive than danish oil with about the same results. Now I mix my own danish oil which is even cheaper...even parts of boiled linseed oil, mineral spirits and varnish. I've heard that pure tounge oil takes forever to dry, but never tried it.
    My Website
    11,834
    Have used it.
    Like it.
    Pure only.
    Like it, easy to apply, looks good.
    Made from the tung nut, whatever that is and wherever it comes from. Is a tough finish that can be added to. It very moisture resistant. Idiot proof in applying. DAMHIK
    I think it is made from the same Martian fish oil as WD-40.
    Jan 2011
    Tacoma, WA
    274
    I like tung oil. It's easy to use, very durable, easy to repair/touchup.
    First coat mix 1/2 and 1/2 with mineral spirits so it soaks into the wood better.
    Does take a while to dry, but over a 3 day period in a warm shop I can get a good 4-5 coats (until the wood stops soaking it up, wood type depending). Does take a day or two or three before it stops seeping out of the poors and is ready to use. At least that was my experience on a rocking chair I rebuilt. .(maybe I put too much on?)
    Also, it doesn't taste too bad when you get it on your hands and then get it on your P&J sandwich.
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    Inside the Beltway
    2,666
    "Tung oil or China wood oil is a drying oil obtained by pressing the seed from the nut of the tung tree (Vernicia fordii). [...] The oil and its use are believed to have originated long ago in China, and appear in the writings of Confucius from about 400 B.C."
    I've used it, but found it takes forever to dry. I'm likely just using it wrong...
    Bill
    2,784
    I used Formby's on the kitchen cabinets at the other house. It worked well and was durable enough. Now I'm using the Waterlox. I think this is tung oil that is already thinned, am I right? Anyway, I love it. Easy to apply, easy to repair if need be. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Mar 2010
    Decatur, Alabama
    518
    I thought I used pure tung oil once, and liked it. Then figured out it wasn't really tongue oil, but a mixed finish. Gotta be careful on that stuff, probably more mixtures with little/no tung oil than true tung oil.
    I've used the polymerized pure tung oil that Lee Valley sells. The polymerization process supposedly causes it to cure faster than unadulterated pure tung oil. I still prefer the results I get with Formby's Tung Oil Finish, and I think it's the varnish in the mix that helps me get a better, more consistent and predictable finish.
    For me, I've found I get better results with any of the oil finishes if I wipe it on, then wipe all the excess up after a few minutes. The only times I can think of when I didn't like the results I got were times that I didn't wipe off the excess before it started hardening.
    Jun 2010
    3,220
    Since this thread hasn't exactly caught on fire, let me rephrase my question and add some information.
    I'm writing an article for a ww magazine on Tung Oil. Is there anyone out there, amateur or pro, would is interested in experimenting with Tung Oil, maybe finishing a couple of small things or showing me photos of already finished projects (with Tung Oil), and who would like to talk about it "on the record" and get some free press ?
    AKA The Rookie
    Dec 2008
    Santa Claus, In
    4,779
    2460 post's and you are writing articles now? Good job
  1. Can Tung oil go bad?
    By Toni Ciuraneta in forum Finishing School
    Last Post: 02-18-2014, 07:44 PM
  2. Teak vs tung oil?
    By Ned Bulken in forum Finishing School
    Last Post: 08-18-2012, 01:11 AM
  3. Tung Oil
    Last Post: 12-05-2011, 08:08 PM
  4. Lee Valley Tung Oil
    Last Post: 08-25-2011, 11:45 PM
  5. Tung oil on MDF?
    By Brian Altop in forum Finishing School
    Last Post: 03-28-2011, 10:13 PM
