Results 1 to 10 of 21
Thread: To glue both sides, or just one side of the joint?
    Jan 2011
    Tacoma, WA
    274
    When using a glue such as tightbond etc, should you glue both sides of the joint, or just one?
    I know that with some polyurethanes you can glue just one side.
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    17,475
    i glue both sides on some, on mortise and tenon i glue the mortise side and not the tenon it just gobs up at the shoulder area on top. on cabinets i glue both the mortise area and tenon on the door frames but i do brush it so as to control the squeeze out.
    I usually put a light coat of glue on both sides, just to make sure. Remember, glue is the cheapest part of your project - no reason to skimp.
    With Titebond, I put glue on both sides. With poly glues, I've done the 'glue one side and dampen the other' routine and had no failures. (I don't use poly glue very often though.)
    Dec 2008
    Santa Claus, In
    4,779
    Another vote for both sides.
    10,604
    Always both sides for me with titebond. I don't use poly glue anymore.
    Independence, Kentucky
    1,355
    Both side here also with Titebond.
    Chuck
    Both sides here as well
    5,323
    Both sides, but a very light coat. Excessive squeezeout is NOT your friend.
    I always used to laugh at Norm's glue-ups. It was like "the bigger the glob, the better the job."
    As for poly - I haven't used that stuff in years!
    Indianapolis area
    1,697
    I coat both sides with a thin coat of glue--usually TB II.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
  2. question about a glue joint failure
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 01-13-2015, 04:22 PM
  3. So Calif fire on three sides of me
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 05-15-2014, 07:04 AM
  4. Albright & Son percussion side by side
    Last Post: 12-09-2011, 04:13 PM
  5. Locking Drawer Glue Joint
    By Tom Blank in forum General Woodworking Q&A
    Last Post: 09-14-2011, 05:17 PM
