Results 1 to 9 of 9
Thread: LV Turners Polish
    Feb 2011
    Ladner BC
    42
    LV Turners Polish
    Hey everyone. I recently inherited a few plastic bottles of LV Turners Polish. I had hoped to be able to use it on some of my smaller turnings but just can't figure out how to use it.
    Has anyone tried it and if so were you able to get a nice high shine?
    Pete
    http://www.woodbowlsandthings.com
    30,237
    How are you applying it, and what problems are you seeing, Peter? I've not used it, but from the description on the Lee Valley website, it looks like it is supposed to be applied to the piece while it's on the lathe, turning at low speed.
    Feb 2011
    Ladner BC
    42
    LV Turners Polish
    Hey Vaughn. Thanks for the reply. I just seem to get a bit of a sticky finish. I too read the LV website information but at low speed nothing much happens. If it is anything like a 'polish' I must be doing something wrong. Not sure if I should apply at low speed and then 'crank' the lathe up and try to heat it with a dry rag or the one I applied with or ??? Just doesn't seem to work right for me somehow but my past brother in law seem to use it to great advantage.
    Pete
    Aug 2008
    Reno, Nv
    3,632
    Hey Peter...Can you tell what the ingredientsí are? It's sounding like a friction polish if you get a sticky feel at low speed. If its wax and shellac, speed it up...1800'ish if possible and try a microfiber towel...should get a moderate sheen.
    Feb 2011
    Ladner BC
    42
    Hi Jim. The label says it has:
    ethanol
    ethalacetate
    methanol
    dipentene
    Pete
    30,237
    Pete, if it's staying sticky and not getting hard, I strongly suspect it's because the finish is old. I've had similar finishes that didn't want to cure right, and replacing them with newer bottles fixed the problem.
    Jim, from what I'm seeing on the Lee Valley site, it's a lacquer based finish, not the typical shellac/wax combo that most friction polishes are made of. I suspect that's why Lee Valley says to apply it at low speed.
    Feb 2011
    Ladner BC
    42
    Thanks Vaughn, your are probably right. I'll try a new bottle to see if it's better BEFORE I toss out the ones I have.
    Pete
    30,237
    ...Jim, from what I'm seeing on the Lee Valley site, it's a lacquer based finish, not the typical shellac/wax combo that most friction polishes are made of. I suspect that's why Lee Valley says to apply it at low speed.
    Oops, I take that back. Re-reading the info shows that it is indeed shellac based. (Although they don't mention any wax.) It may indeed respond to higher lathe speeds.
    Still, my first guess for the cause of slow or no curing would be the age of the inherited finish.
    Feb 2011
    Ladner BC
    42
    Thanks again for the information. When I next try to finish a piece I'll let you know. Today I am giving a small talk and presentation about wood lathes to my 8 year old grandson's school class. Should be fun.
    Pete
  1. "Black Polish" / Black French Polish
    By gavin dj harper in forum Finishing School
    Last Post: 05-19-2011, 05:56 PM
  2. French polish or Padding...
    By James Edwards in forum Finishing School
    Last Post: 08-22-2009, 01:26 PM
  3. For the pen turners
    Last Post: 10-15-2008, 02:33 PM
  4. Friction Polish
    By Cody Colston in forum General Woodturning Q&A
    Last Post: 06-22-2008, 02:48 PM
  5. For you turners
    By larry merlau in forum General Woodturning Q&A
    Last Post: 05-18-2007, 12:34 PM
