Results 1 to 10 of 18
Thread: Turning Plywood
    Feb 2011
    Salem, OR
    267
    Turning Plywood
    This is my first attempt at turning plywood and I had a problem will some of the layers pulling fiber instead of cutting and I was using a sharp tool. Has anyone else had this issue? Are there any tips that would help stop this from happening?
    Aug 2008
    Reno, Nv
    3,632
    Hey Jim,
    Looks like you cut squares, glued them into a stack and that was your blank. You are braver than I am sir! Since the plys are so thin, some tear out is expected. Maybe change your cut to a shear and since it's all end grain, get a good burr on that scaper.
    Nov 2008
    Tampa & NC
    432
    Turning Plywood
    For one thing you can't turn CHEAP grade plywood with any success., You should use a good furniture grade plywood,because the cheap stuff is not glued up very well and is full of voids.I have never turned it,but have seen many very nice pieces turned from it.good luck.
    May God Bless
    Ken
    30,017
    That came out looking cool, Jim. I'm assuming you dyed the outside. Is that correct?
    I think the tearout problem you're seeing would be helped with careful tool presentation (shearing cuts for the final few passes) and very sharp tools.
    Feb 2011
    Salem, OR
    267
    Thanks. Yes, I used a dark blue dye and then sanded it with some 400 grit. It's Baltic Birch Plywood top grade.
    Jan 2011
    3,798
    Can't help, but can compliment...Very nice!
    Oct 2010
    Abq, NM
    312
    Much nicer than I would have imagined. Good job and I love the dye!
    Goodland, Kansas
    4,834
    I have turned a couple of plywood bowls and you have to be fairly careful. That one turned out nice especially with the color.
    Bernie W.
    North West Indiana
    6,098
    Very nice!! Were you by chance using a carbide tool like a Ci1??
    Jon
    Nov 2008
    Tampa & NC
    432
    Turning Plywood
    Don't see how in the devil I missed the pic but anyway it is a beautifull piece.Like I said in my 1st reply on this,the cheap grade ply has way to many voids and air pockets to turn decent pieces from,but you did great with the birch
    May God Bless
    Ken
  1. Turning, turning turning .......woodside .........
    By Dave Hawksford in forum Turning Tool Questions and Show & Tell
    Last Post: 04-09-2014, 04:17 AM
  2. Plywood (from where)
    By Paul M Cohen in forum Carpentry and Construction
    Last Post: 05-30-2008, 02:38 PM
  3. Can your plywood do this??
    Last Post: 04-02-2008, 06:48 PM
  4. Plywood
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 03-21-2007, 02:29 AM
  5. Plywood is good for turning!
    By Michael Robertson in forum Lathe Project Showcase
    Last Post: 03-18-2007, 03:26 PM
