Results 1 to 10 of 10
Thread: New Router Plane, Handbuilt
    May 2008
    Bellevue, WA
    38
    Lightbulb New Router Plane, Handbuilt
    I've got a couple of projects coming up that I will need (want?) a router plane for some dado and grooves. Being somewhat tight, and also wondering if I could make one, so I took on the challenge. I did cheat a bit; bought a Lee Valley router plane blade (1/2" square). Other than the drill press it was all done with hand tools.
    After looking around on the internet and through my books, melded several ideas and came up with this design.
    Actually, its the 2nd version. The first version had the blade set too far forward, but it will work if I need a bull nosed router plane.
    It was built out of scraps that were laying around. The base is either high quality chip board, or coarse mdf. The rest is poplar and plywood. Joints are simple rabbets with part glued and screwed together.
    What you see is a piece of pine for the test piece. I got the dado started with a couple of saw cuts to form the sides, then took the plane to it. With the grain it cuts easy and fairly smoothly. Across grain, not so smooth, but does the job.
    It will do the jobs I have lined up. I'll give it a couple coats of some kind of finish and wax the sole. I will probably buy a couple of more blades, a 1/4" and the pointed 1/2".
    If nothing else, it has got me back in the shop and making saw dust after finishing ski season.
    Attached Thumbnails Attached Thumbnails 100_3235a.jpg   100_3237a.jpg   100_3238a.jpg
    Los Angeles, CA
    2,668
    Nicw work Richard. It looks very functional.
    13,361
    That oughta 'git-r-dun'!
    5,322
    Pretty doggone neat, Richard!
    As for cheating on the blade - no, not really...but you can always make other blades for it by grinding down some Allen wrenches.
    May 2008
    Bellevue, WA
    38
    Thanks
    Thanks for the nice words. Its not a thing of beauty, but I wasn't really trying for that, however I may still spruce it up a bit.
    Jim, I had thought about making a blade out of an allen wrench, but my grinder skills aren't a thing of confidence. Besides the LV blades aren't that pricey.
    Jun 2007
    4,944
    And besides that the commercial blades are MUCH better steel.
    It looks great. I hope it gets you in the groove.
    Enjoy,
    Jim
    VOTING MEMBER
    Feb 2009
    Whittier, CA, USA
    512
    I like it! Will keep your little project in mind and copy it in pure admiration when necessary.
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    10,604
    Really neat Looks like it will work great.
    Central NY State
    3,374
    Groovy.
    [groan]
    Quote Originally Posted by ken werner View Post
    Groovy.
    [groan]
    Boo.... Hisss...
    That router plane looks great, and hey, if it works that well on pine, you must be doing something right!
  1. Interesting new router plane
    By Ryan Mooney in forum Neander Tool Questions and Show & Tell
    Last Post: 03-24-2016, 10:57 PM
  2. Small Router Plane
    By Jim DeLaney in forum Handtool Project Showcase
    Last Post: 10-17-2013, 07:22 PM
  3. Plane gloat - rabbet plane
    Last Post: 03-21-2012, 09:08 PM
  4. Flush Plane / Flat Chisel Plane
    By Richard Line in forum Neander Tool Questions and Show & Tell
    Last Post: 10-06-2009, 09:12 AM
  5. A refurbed small bronze router plane
    By Dominic Greco in forum Neander Tool Questions and Show & Tell
    Last Post: 08-10-2008, 04:34 AM
